ideal set up for an F1A
so if you wanted to hit around 750-800 rwp what would the ideal set up be for an F1A? 383,427 what? what about boost levels and intake manifold?
A relatively inexpensive way to do it would be with a 6.0L iron block, and a 4.0" stroker crankshaft. The new Callies Compstar crank at approx $700.00 would be a great way to go, much better than an Eagle crankshaft. This combination would give you a 402.
A 402 using an LS2 aluminum block would save you some weight in the block, but ends up costing a lot more. These combinations would make you an easy 800 rwhp with good flowing heads and a good cam with an F1A ProCharger blower.
I'd use the G.M. LS6 intake manifold. Bob
Originally Posted by TS6
My 408 with a D1SC made 757 RWHP with 14 psi, so I would think an F1A would be able to do it with even less boost.
Originally Posted by 52172
Go with what Bob said and for heads get l92's and l76 intake manifold and that will save even more money.
