OFI downpipes are ready
All of you waiting on the Downpipes they are now done. Stainless works worked there *** off as usuall for me. Thanks Al and chuck at SW. I will go up there and pick them up on tuesday if everything goes good around here. Just need to call jose and get some flanges. Then I will mock them up with the kit here and see how they fit.
Also I have recived a UMI k member to make the 4" dowpipe upgrade available in the coming weeks. See how it goes. I know I could just move the alt, but I would rather not. Like to try and keep all the acc in the stock locations. Will have some more pics later.
Thanks Joel
Thanks Joel
Originally Posted by cablebandit
yaayyyy Joel. So when is mine going to the coater? As far as the 4" dp....how long we talking cause i have a bmr kmember and wouldnt mind moving the alternator if needed. How much is that over a 3.5 dp?
Joel i hope your *** gets snowed in...at the shop!!!
Originally Posted by ninetres
I have a UMI k-member and there is no way to fit a 4" DP. A 3.5" would even be cutting it. I have 6.0 manifolds though, so maybe that is the difference.
[QUOTE=tt427ls1]All of you waiting on the Downpipes they are now done. QUOTE]
Joel, I know you probably busy and all but I would really like an update on the rest of my kit. We're going on 3 1/2 months here and spring is just around the corner...
If everything isn't ready to ship I at least really need the crossover so I can start mocking things up. I can't do anything with what I have so far...
[QUOTE=SSblack98] I will get your stuff out this week chad. I am closed on mondays and tosay was a crazy day at home. The wifes car has no headlight for some reason and no daytime running lights. Been trying to fix it all day. Even got a book on the wiring of the car. Lots of relays and drl modules. Damn BCM...I hate it.
[QUOTE=tt427ls1]
I will get your stuff out this week chad. I am closed on mondays and tosay was a crazy day at home. The wifes car has no headlight for some reason and no daytime running lights. Been trying to fix it all day. Even got a book on the wiring of the car. Lots of relays and drl modules. Damn BCM...I hate it. Thanks for the update Joel, just getting really antsy here as you can imagine...
Is your wife's car a GM vehicle? I'm a tech at a GM dealer and might be able to help...
