Cam suggestion (patrick G, Predator Help please)
I'm cammin my car this summer and i need help with picking a grind. Im gonna get patriots ported 243's milled to 61cc's with a .040 cometic gasket. i don't want to fly cut and i would like to hit at least 400 rwhp. cam gurus please grace me with you expertise.
Originally Posted by JPH
i did 400rwhp/385rwtrq with a crane 220/224 .585/.585 114+4 and those heads. But i did use crane 1.8 rockers to achieve that lift, and get a little more out of the cam. i was disappointed with the heads hp performance. i suggest 224/228 .585/.585 112+2.
Originally Posted by YankeeVert.
Why not use the comp XER lobes? 220/224 .581/.581 and save the cost of the 1.8 rockers?
i was wanting to go a little bigger than a 224 but not over 230. because i want to be happy with the cam. but i don't wanna be changing springs all the time.
crane #1449601, but you will to flycut.
more info
https://ls1tech.com/forums/dynamometer-results-comparisons/630308-home-ported-241-400-rwtq-3500rpm.html
LS1 Tech Administrator
You could have gotten over 400 rwhp cam-only. Breaking 400 rwhp with PP 243 heads milled to 61cc and a .040" gasket can almost be accomplished with the stock cam. Now you need to ask yourself the question, how much over 400 rwhp do I want? There's no free lunch as the additional overlap will take a potential toll on street manners, but you won't need lots duration to get there. What is the max lift that you are willing to run? Using anything better than PP Golds for springs?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by prostock_bigblock
we had good results from it. we made 440+ rwhp and 400+rwtq from 3500 rpm with this cam + home ported 241s with bigger valves + stock 10:1 C/R .
more info
https://ls1tech.com/forums/showthread.php?t=630308
more info
Originally Posted by onebadrubi
Whats wrong with the PP gold springs?
__________________
Nothing wrong with them. They just won't allow you to run LSK lobes, that's why I asked. You'd need the Patriot Extreme springs to run the LSK lobes.
Which are pretty much the same price.
It is a stronger spring, but is just as available, and as said similar in price.
IMO go with something like a PRC street or Patriot's higher end head, that with the 224/228 580s will make your car scream, and be totally drivable.
