Home ported 241 400+ rwtq on 3500rpm
Heyy all this is one of my freinds car . Its a 98 camaro with the following mods:-
241 home ported heads with 2.02/1.6 valves.
228/232 112 lsa.
Asp UD.
ls6 intake and home ported Tb
ls6 clutch with aluminium flywheel
LTs with TDs to the all way back
stock 10:1 compression ratio.
stock injectors and they were maxing out.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
228/232 112 lsa.
Asp UD.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
the car owner is planning to squeeze out more power by adding more timing, maybe 31*, add a cutout, 32 injectors, 85 mass air and probably a match ported fast.
the car has alot left also in the tuning, the guy who tuned is a beginner and tuned it on open lope (WOT) .
228/232 112 lsa.
Asp UD.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
228/232 112 lsa.
Asp UD.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
something is wrong with the graph... the tq and HP dont cross at 5250
im gonna go ahead and raise the
Originally Posted by pianoprodigy
Look at the scaling. The HP and TQ are on different Y axis scales.
228/232 112 lsa.
Asp UD.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
228/232 112 lsa.
Asp UD.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
prostock_bigblock, see my thread https://ls1tech.com/forums/showthrea...8&page=1&pp=10
can you e-mail me the way on how did you port the 241 heads! thanks.
