Window Wiper Arm Help
Old 02-12-2007, 06:50 PM
SlowBurn's Avatar
Default Window Wiper Arm Help
I accidentally snapped my wiper arm not too long ago. I bought a new one, but I'm having trouble removing the old arm (where it mounts to the window motor). I removed the nut that holds it on, but it seems to be pressed on so tightly that I can't seem to pull it off. Any hints or tips to getting this sucker off without tearing my window motor out at the same time?
Old 02-12-2007, 09:48 PM
SlowBurn's Avatar
Anyone?
Old 02-12-2007, 11:40 PM
SlowBurn's Avatar
Old 02-13-2007, 08:00 AM
Michael02hawk's Avatar
Dont force or pry it, you'll end up breaking your windshield!
Go to an auto store, and buy the wiper arm removal tool. Its under $10, I found mine at Advanced Auto, but everyone sells it.
Old 02-13-2007, 08:18 AM
Weezzer's Avatar
You can also use a battery terminal puller.
Old 02-13-2007, 11:44 PM
SlowBurn's Avatar
Muchas Gracias
Old 02-14-2007, 09:17 AM
keliente's Avatar
Or pull up on the arm and smack the end of the threaded rod with a hammer.
Old 02-14-2007, 02:06 PM
Flawless02SS's Avatar
I tried all that, my hood is in the way to get any of the tools on the arm good.
Old 02-15-2007, 03:29 AM
01Z28M6's Avatar
I bought the Advance wiper arm removal tool and broke the plastic **** but it finished the job. I used vice grips or something to continue turning the pintle. If memory serves me I think I moved the arm to about 1/3 up the windshield by turning the wiper on and switching the ignition off when the arm reached that point. I may have even lowered the hood a bit for clearance. I was just able to get the tool in position. Removing the arm was a fight every fraction of the way. It popped and there was a tiny cloud of dust as it broke free.
The **** couldn't take the pressure:
Old 02-15-2007, 03:39 AM
01Z28M6's Avatar
One caution here. Be careful when removing the wiper arm. This is what I found after buying my 2001. I think it was from someone horsing the wiper arm. I can't think of any other reason. With all due respect, I would never strike down on the spindle.
