fabricated turbo!!!
Old 02-13-2007, 11:45 AM
DMONEY06's Avatar
Default fabricated turbo!!!
could u buy the any kind of turbo and fabricate it to be like the STS kit? or does it have to be specificly made for these cars?? i wanna go FI real bad but on a budget i could easily get a turbo for real cheap plus any other parts that i need!
Old 02-13-2007, 11:50 AM
52172's Avatar
Go big or go home!!!
Old 02-13-2007, 11:52 AM
pdanrichey's Avatar
The STS kits use Garrett turbos. I'd be cautious about buying a "cheap" turbo though...if anything, don't skimp on that part of your kit.
All the electronics and such that go with it though are quite the ordeal...I'd be weary about taking on that kind of task. Yes, it can be done but you're talking about spending some serious time putting everything together.
Also, ALWAYS plan on spending A LOT more $$$ than you think you're going to spend. Looking back, I'm kicking myself for thinking I could turbo my car for less than $5k... The worst part is, now that it's almost there, within a short period of time, I'll have to upgrade the clutch, brakes, tires, etc etc etc...it just keeps adding up !!
Old 02-13-2007, 12:01 PM
6techniques's Avatar
Yes, you can fabricate your own system. And any kind of system that you make/or have made, will obviously have to be for your car.
Since I dont know what your idea of what "cheap" is, how much of a budget are you working with?
Old 02-13-2007, 12:05 PM
MIGHTYMOUSE's Avatar
1. what kind of wheels are those?
2. don't do fi if you are looking for cheap and easy, and 'a turbo' and 'other parts' are really not the hard part of the deal
Old 02-13-2007, 12:36 PM
HAMRHEAD's Avatar
Don't cut yourself close financially with an FI setup or you will always come up short. Just go with N2O if money is a concern
Old 02-13-2007, 12:52 PM
SSilverSSurfer's Avatar
Originally Posted by MIGHTYMOUSE
1. what kind of wheels are those?2. don't do fi if you are looking for cheap and easy, and 'a turbo' and 'other parts' are really not the hard part of the deal
they look like C6 wheels,
cheap and FI is like water and oil
Old 02-13-2007, 03:24 PM
engineermike's Avatar
"turbo" and "cheap" don't belong in the same post.
Old 02-13-2007, 04:44 PM
DMONEY06's Avatar
yea they are c6 wheels
Old 02-13-2007, 04:52 PM
mahhddgtp's Avatar
Turbo + Cheap = car out of commission for 4 months while you save money to fix with parts you should've been using for the build all along
Old 02-13-2007, 06:43 PM
Bird-Of-Prey's Avatar
You got that right
Old 02-14-2007, 02:00 AM
chuntington101's Avatar
it not too hard to make a "cheap" turbo setup. take one T70 (on stock size engine). then go to a exhaust shop and get them to make the hot and cold tubing up for you. obviously a over to let them drive it and a few cans of beer will help with any worries of quality to! they should also beable to fab the weastgate and BOV stuff. then you will need an ally intercooler.
there are of course LOADS of other little bits and bobs, but you dont have to spend the earth!
Chris.
Old 02-14-2007, 07:00 AM
Chris.
are you kidding dude? i can't tell.
Old 02-14-2007, 03:56 PM
cablebandit's Avatar
i think he was high.....and now that you mentioned it.............
Old 02-14-2007, 05:02 PM
Jake@EPP's Avatar
So Midas and Fair Muffler do turbo systems? Do they include high quality crush bent pipes and ebay turbos?
Old 02-14-2007, 07:11 PM
grifftransam's Avatar
you could probably use most of your stock exhaust system. cut it off at the muffler, fab the turbo in, run a splitter off that so you can keep the dual look. its possible, mabey not the most reliable setup, but doable for sure.
your not gonna gain a ton of power without experienced tunning, but you should pick up a bit.
Old 02-14-2007, 09:31 PM
man those comments get to me. its crazy how many people think that rear mount is THE place to do a turbo on these cars..argh!
if i have to explain to one more person why my turbo is under the hood and not in place of the muffler like they heard about on tv....
Old 02-15-2007, 03:30 AM
x eleventy billion!
Old 02-15-2007, 05:45 AM
01ramair500hp's Avatar
so why did you put it under your hood???
Old 02-15-2007, 02:33 PM
under the hood is where mine is going but im curious as to your reasoning mightymouse
Quick Reply: fabricated turbo!!!
