Where to connect steam tube LS2/LS7?
Old 02-14-2007, 10:24 AM
Wardrum's Avatar
Default Where to connect steam tube LS2/LS7?
I need to order a radiator for my LS7 project and am trying to decide the best place to connect the steam tube to. Direct to radiator....or to one of the hoses? I don't want to drill and tap the water pump if possible. Any pics showing how you did it would be great. Thanks!!
Old 02-14-2007, 10:43 AM
Andy1's Avatar
I suppose it depends a lot on your particular needs, space, and cosmetics (if that applies). If you're running a filler tank, you could plumb them there. Otherwise, the top of the radiator like a Camaro, etc., is it. BTW, these guys have a nice steam vent adapter fror 1/8 NPT which allows for running any kind of line; AN, hose, etc. They're cheap as well.
http://s41657.sites80.storefront-hos...l.aspx?ID=3289
Andy1
Old 02-15-2007, 09:14 PM
CorvetteTechInc's Avatar
Another option is to just drill and tap a hole in the top of the waterpump and screw a bung into it and run the hose down just a couple of inches. Can't even see it when done and doesn't require a modification to the radiator or elsewhere.
Old 02-15-2007, 10:04 PM
70CamaroRS_LS1's Avatar
I made an insert that I inserted into the upper hose near the vent tube. Just used a piece of exhaust tubing and welded in a bung. Then ran a beed around the OD to give the hose something to seal on. It's self explanitory buy I can get you a pic if you need.
Old 02-16-2007, 10:12 AM
mr2guru's Avatar
Andy1
Those are sweet! I just bought some. That'll clean up nicely and I can run a rear crossover along with the fron vent with -3an
Old 02-16-2007, 11:16 AM
Wardrum's Avatar
Thanks. $5.00 for the adapter and they are right down the road from me.
Old 02-16-2007, 01:14 PM
cam
cam's Avatar
The steam tube should be plumbed into the highest point of the cooling system to avoid air locks. I am surprised that they guys who tap it into the water pump have not had problems
Old 02-16-2007, 02:12 PM
Darracq's Avatar
Could i just plug them up?
Old 02-16-2007, 02:17 PM
cam
cam's Avatar
No plugging them is not good. The rear two came plugged on Z06's because the front two are higher ( from level ) than the rear so the steam migrates forwards and up and out the front two but it seems when LS1's take out a cyl its usuallly at the rear of the engine caused either by air crashing into the intake leaning out the rear cyls or maybe the steam tubes being plugged causing concentrated overheat leading to lean condition and kaboom.
Dont plug them plumb them
Old 02-16-2007, 02:19 PM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
On some applications it is plumbed low right from the factory so going into the water pump is fine.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old 02-16-2007, 02:25 PM
cam
cam's Avatar
Hmm learn sumthin new everyday first I heard of it.
Old 02-16-2007, 02:31 PM
rigi's Avatar
I am also going to order a radiator from Streetrodstuff for my 57 project with 1999 Camaro LS-1 .
Where do you recommend to mount the outlets and do I need extra fittings more than one vent hose fitting?
Old 02-16-2007, 02:55 PM
Speartech's Avatar
Here's my 5.3 GMC Envoy engine. The black hose is the the steam line. It is tee'd into the heater hose just a few inches above the ports on the side of the water pump. This is the stock factory setup.
__________________
www.speartech.com
Old 02-16-2007, 03:07 PM
cam
cam's Avatar
Looks like its higher than the highest point of the engine or is it the pic? Tapping the top of the water pump would put it below the high point.
Old 02-16-2007, 10:32 PM
sawzall wielding director
G-Body's Avatar
I "T" ed into the heater hose with my car when I put it together because I did not have an extra bung in my radiator. I did not notice any problems, but ever since I put the car together the heat has not been as hot as before. At least twice I pulled the hoses by the heater core and noticed it was air bound, I wonder if the TB bypass has been pushing air into my heater core. I know that I have an air pocket in my upper radiator hose because it is the highest point in the system, maybe the air was making its way into the engine, coming out the TB bypass and ending up in my heater core????
Anyway I now have a radiator with an extra bung so I guess I `ll have to change it and see what happens. I`ll post back with what I find, but it probably won`t be for a couple weeks, I have final exams next week so the only thing I`m doing is studying I`ll try and change it the week after and see how it works out.
Old 02-17-2007, 02:04 AM
cam
cam's Avatar
I got a little curious about this so I checked and found according to the GM LS1 swap installation guide ( pn 88959384 ) it states on page 7;
Connect cylinder head air bleeds and coolant return line to outlet radiator hose or return side of radiator. Cylinder heads air bleeds must connect to fill bottle or highest point of cooling system above coolant level!
Thats an exact quote they even put the exclamation mark so....
Then it says;
NOTE: failure to connect the cylinder head air bleeds properly can cause an internal air lock and result in engine damage
take it as you will
Old 02-19-2007, 07:36 PM
FirstGen's Avatar
Sounds dangerous however I ran with the air bleeds connected from one head to the other and not re-circulated back into the coolant system at all for over a year on a previous 6.0 swap...
Never had any over heating problems or anything like that...
Old 02-19-2007, 11:03 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
He already said it was lower. Why would he make up stuff? Oh...fooled you. Its really higher but I am going to make up ****....
Andrew
Old 02-20-2007, 12:13 AM
cam
cam's Avatar
Drat! Thow arts a bowlngrekentuckyin!!!
Theres photos of all online if you search. I only wish to offer that of best knowledge possible.
Old 02-20-2007, 06:44 AM
I am about as much a bowlngrenkentuckyin as you are.
As for offering the best knowledge possible, this topic has been covered as least a half dozen times already. John has posted that picture of his Envoy at least 2 times.
Andrew
Quick Reply: Where to connect steam tube LS2/LS7?
