Q trim vs P trim
Old 02-15-2007, 06:13 PM
Juiced's Avatar
Default Q trim vs P trim
How much more will a q trim wheel flow than a p trim on a 70mm turbo?
Old 02-15-2007, 06:21 PM
LS1TECH Sponsor
DrTurbo's Avatar
ALOT more. A p-trim on a 70mm will choke off much earlier. Also depends on which Q-trim your are talking. Their are several different versions of them now.
Old 02-15-2007, 06:24 PM
Juiced's Avatar
Lets just say the standard or "tradditional" q trim....
How much more power can it support?
Old 02-17-2007, 12:21 PM
TOTM: November '07
explorer5.0's Avatar
If it is a street car, I'd go for the P-trim; if it is a track car, I'd get the Q-trim. The Q will make power much later in the powerband.
Old 02-19-2007, 09:08 AM
LS1TECH Sponsor
DrTurbo's Avatar
I hope your kidding with that statement. On an LS1 their is no much later about anything other then if you slap a Thumper on it.
Old 02-19-2007, 01:39 PM
Zombie's Avatar
Horrible advice, would not read again.
Old 02-19-2007, 06:05 PM
engineermike's Avatar
Yep, both are too small for 346 cid.
Old 02-19-2007, 10:31 PM
xxxhp's Avatar
What about a twin setup with a P-trim on each turbo? That's my current setup
Old 02-21-2007, 02:28 PM
TOTM: November '07
What I really meant was that if you want to make more top end power, go with the Q. It will be more efficent in the top end than the P. Many say that even the Q-trim is too small, but I would prefer the low end power. ..But it seems not many people use P or Q-trims on LSx motors unless it is remote mount anyway.
And, the guy asking the question has an LT1
Old 02-21-2007, 03:56 PM
Juiced's Avatar
Actually it's an lt1 shell..... car has a W2W LSX motor.....
Old 02-21-2007, 04:34 PM
SSilverSSurfer's Avatar
im using a q trim on a front mount, not running yet but i'll let you guys know when it is
Old 02-21-2007, 07:35 PM
turbocuda's Avatar
I run a 408ci small block mopar with ported edelbrock heads/r3 block callies dragon slayer crank, manley pro-series rods and custom ross turbo/blower pistons...accel dfi w/72lb'rs and twin 61mm masterpowers with .68ar p-trim turbines....from reading some other posts on turbomustangs, dave with majestic was reading almost over 2-1 back pressure with twin p-trim .68ars...on his 383 ci....
with my solid 245/245 cam i plan on turning 6800-7000rpm....I may be upsizing down the road to .96 ar's
Old 02-22-2007, 12:44 PM
Juiced's Avatar
cool build.... they look so small under the hood of a mopar.......
Quick Reply: Q trim vs P trim
