How far out will 13mm and 15 mm offset wheels stick?
I found a set of Stern wheels...but the offset is 13mm for the front and 15mm for the rear...the wheel guide says you can't go that low...is it because they'll stick out really far or what?
Damnit...Man it's hard as hell to find a nice set of wheels that nobody has for a decent price (under $1000). I found some Sterns that I love, I've seen them on a 300ZX and they looked great but damnit I don't want wheels sticking out that far. Grrr, this pisses me off...
http://cgi.ebay.com/ebaymotors/19-ST...QQcmdZViewItem
by the way. I may be wrong here. but with those sizes/offset. I dont think that they would stick out. I think you'd be fine.but i'll let xsta z28 chime in after seeing your sizes.
Originally Posted by 02NBMWS6
they may fit but theyre gonna stick out like a m'fer. dont go anymore than 38mm at the most man
if it makes you feel anybetter. 6 spokes = . I wouldnt get those.
even on a 8.5? looks like i might be thinking aobut this all wrong.
i dont think the width matters when youre talking about offset man, except for clearance issues with the inner fenders
As the rim width get narrower, the amount of positive offset has to shrink at half the rate to keep the tire centered.
When you have a rim widened you have to add a spacer to increase the offset. For instance, a 2 inch width increase would need a 1" spacer. This changes the offset to compensate to the wider width and keep the tire centered.
Does that make sense?
