Forced Induction - PCV on STS HELP!!!
JD_Z28
02-16-2007, 05:52 PM
Sorry to bring this up again you guys. Can anyone please help me setup a simple and effective PCV setup. I've tried everything and no matter what I do I keep getting blowby out the breather. I'm trying to work with what I have and thats 2 small Home Depot CC's and 1 check valve. Can somebody please help me out My last setup I ran a check valve between the manifold and pcv along with a Home Depot cc, I plugged the TB and ran a breather right off the passenger side valve cover. Any help is highly appreciated.
Thanks,
John
Schantin
02-16-2007, 06:53 PM
Went a differernt route. STS PCV bypass to an AMW atchcan, then to the PCV valve. It seems the catch can vents the pressure. I already had the can when the car was NA....and plugged the STS PCV switch right into the system. No real thought behind it when I did it.....but it does seem to work well. :)
RooRnZ28
02-16-2007, 08:46 PM
need info as well.... TTT for ya!!
98turbls1
02-16-2007, 08:56 PM
There should be a sticky on this subject and how to route a properly tried and true PCV system for FM turbo, RM turbo, Supercharger, and whatever else someone can think of... TTT for you John...
SilverSS
02-16-2007, 09:15 PM
+1 :judge:
JAvenger007
02-17-2007, 03:26 PM
This can be a little tough because of how much people are willing to spend on their setups. Regardless i think if someone posted up a good starting place or at least a basic layout for others to follow, we would greatly cut down the amount of PCV threads.
Eatinstang4life
02-18-2007, 12:39 PM
any pics of your set up?
jeffboy757
02-19-2007, 06:38 PM
need some pics / info on someone with a good pcv setup
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
