not shifting out of 2nd till 50-60mph
I'm looking at a 95 Camaro z28 with this problem. I assume it's probaly a shift solenoid problem? Can anyone shed any light on what this could possibly be?
Originally Posted by performabuilt
yes a basic scanner should do and on a 95 look carfully under the dash I have found a couple that year that had both plugs
TTT.. I bought the car and It has a delay shifting into Drive. The fluid is a little burnt in color and is overfilled. The pan is also dented.. Would a overfilled trans make it not shift correctly?
I took the car for a drive after I posted and got on it and it doesn't slip and pulls great through 1st but shifts really harsh into 2nd gear so hard it chirped the tires.
Alright so I finally fixed the coolant leak that was preventing me to drive it far at all (finally had a nice day here).. So, I pulled the plates off my 98 and drove it around for about 10min or so around town and I'm going to describe this as best as I can.. The car shifts 1st through 2nd fine but I couldn't get it into third even upto 65mph (I didn't want to push it on backroads considering the car isn't registered) But I noticed everytime I let off the RPM's would drop to idle and if you get back on the gas the tranny would kind of thud and lock up again. It didn't even try and shift past 1st and 2nd.. no slipping or anything I'm stumped.
LS1Tech Sponsor
TRY unplugging the harness from the trans on passengers side, This wll put the trans in third gear if the 3-4 clutch is intack , It will feel likes its lugging if so then the 3-4 clutch is in one peice if not it will feel like its in first,This will also eliminate any valve body issues since it will prove that if the PCM turns off the two solenoids that 3rd can happen. Have you scanned for codes and do you have and SES light on ?
__________________
LS1Tech Sponsor
its not real bad to get to its on the passengers side just above the pan rail next to the servo, you have to squeeze the wide side to release the plug. What you will be looking for when you do this is wether the car then ends up in thrid gear , You will need to drive it to figure that out , make sure the plug is away from the exhaust , The car will feel ery sluggish taking off and as you increase speed you will be able to tell that its allways in 3rd gear, That is if the 3-4 clutch is ok if not it will still feel like its in first gear,
__________________
LS1Tech Sponsor
Well things just got a bit more complicated . Now you have to figure out why the PCM is not comanding the shift which apparently it is not. You are going to have to 1 plug the harness back in ,2 clear the codes there will be several from having the harness unpluged, 3 get with someone with a scanner who can look at the data stream in that model year and try and see why the command is not happening ,Look at such values as VSS, TPS, TPMS, etc to try and figure it out.
__________________
