coil rail removal help
this is pissing me off so much. Im trying to change the plugs and wires, so i took the air pipe off and now im trying to get the coil rail off. I took the 4 screws out but i cant get back to the very far one with an open end 10mm. how did you guys get to it
You dont need to pull all of that off for a plug change. You just need a few different sized socket extentions and swivels.
If you insist on pulling the coil bracket though I got to it with the socket. Stay patient and take your time. And once you get that one off do not put that back bolt back in, it makes it so much easier for the next time.
Originally Posted by fortmyerspolice
its even a pain in the *** to take the wires off, are you supposed to push those metal springs things in and then pull the boot?
Originally Posted by MY02REDWS6TA
I got that last coil bracket bolt on the passenger side with a 10mm gear wrench.........then I calmly walked out of the garage and threw the bolt as far as I could
Box end 10mm, stay calm, little turns and just loosen it up, quite a bit but not enough get it all the way off. With the box end I did it by feel. Gotta kind of lay over the top of the engine, rest, do more. Tilt the coil rail up out of the way. I know a lot of guys just leave the bolt off, but I'm keeping mine intact. I was worried I might get a rattle if I tossed it. And really, really, toss the damn stock wires with the metal tubes and springs. Put some 8mm or 10mm's on. Taylors are good and easy to get on and off, you don't need the heat shields that the stock ones have. Use the dielectric grease so they come of next time. Oh, and everyone gets pissed off changing wires. The second time will be soo much easier.
Originally Posted by brad8266
Thats funny.
We got a good laugh out of it...................
The funny part was later that day I was standing across the street talking with my neighbor in his driveway and I bent down and picked it up
