No Clutch Pressure!
Old 02-17-2007, 08:09 PM
pro2low's Avatar
Default No Clutch Pressure!
ok so i have been doing some work on my car trans swap, headers...........last night at about 3 am i finally am ready to bleed the clutch and start the car. (i have the bleeder extension thanks to Steve-D) me and my friend are bleeding the clutch. i was in the car and the pedal would stick to the floor everytime and had absolutely no pressure. i asked him if fluid was coming out and he said that there was. i have a 01' 02' master and i just put in a new slave. however when i was thinking of what it could be i remembered that i had forgotten to bench bleed the master again since i was off he car for about a week. could that even be the problem? or did i do something wrong when i installed the slave? thanks for any help -dave-
Old 02-17-2007, 08:15 PM
themack56's Avatar
i had the same prob when i did the my a4 to m6 swap, u probably need to bench bleed ur master, then prefill ur slave with fluid, it should already be prefilled when u buy it from the dealer, but i just bought new master and slave and bleeded the slave for any little air bubbles then vuala it worked
Old 02-17-2007, 08:26 PM
pro2low's Avatar
i dont want to pull my trans again! hopefully if i bench bleed the master and find my mightey vac and just bleed the crap out of it it will be good to go. do you know if i can bench bleed the master with it still in the car? like if i just disconnect it from the slave?
Old 02-17-2007, 08:39 PM
chuckyt1's Avatar
You have to pull the master to bench bleed it. It needs to be kinda level so that air doesn't get trapped up high. I think...
If you can't find your mightyvac - let me know, I'm in the NW burbs also and I've got one...
Old 02-17-2007, 08:40 PM
themack56's Avatar
i say u take it out, and bench bleed from there
Old 02-17-2007, 08:42 PM
pro2low's Avatar
alright cool thanks guys ill work on this tomorrow.....chuckyt1 im in des plaines if that isnt to far from you i might be in contact haha thank you once again
Old 02-17-2007, 08:45 PM
chuckyt1's Avatar
Algonquin...
Old 02-17-2007, 08:48 PM
pro2low's Avatar
ooo i think thats kinda far lol
if i cant find it i can always go to autozone or soemthing and buy another one for like $20 thanks for the offer though i really appreciate it
Old 02-17-2007, 08:53 PM
chuckyt1's Avatar
Anytime... good luck with it...
Old 02-17-2007, 09:02 PM
pro2low's Avatar
ill post tomorrow after i work on it let ya know what happens
Old 02-23-2007, 11:44 PM
yobabiesdaddy2001's Avatar
what happend?
Old 02-24-2007, 08:59 PM
30th t/a's Avatar
yea what happened? im going through this "no clutch pressure deal" myself.
