where are you getting your front runner tires?
Old 02-21-2007, 08:18 PM
nomorews6's Avatar
Default where are you getting your front runner tires?
I have checked this site and people seem to be getting them for $30 each, but wherever I check they are selling for $130 each or so. Where should I go and what should I look for to put on a 15x3.5 pro star?
Old 02-23-2007, 09:38 AM
RZRSEDGE's Avatar
The one's for $30 are small generic tires that are made for smaller cars. Alot of people run them so I guess that they work fine, but keep in mind that are speed rated at like 112-118. If you decide to go that route you can find them at just about any tire shop. I know Pep-Boys has them among others. Hope this helps you out!
Old 02-23-2007, 11:46 AM
LS69TA's Avatar
I went to Tirerack. Kumho Powerstar 165R15s for like $26 a piece.
Old 02-23-2007, 12:53 PM
The Wingman
LilRick's Avatar
I found a kumho 165/80r15. Does the middle number make a difference?
Old 02-23-2007, 01:33 PM
boondiggys's Avatar
the middle number on a tire is the height of the sidewall (in milimeters.)
Old 02-23-2007, 02:33 PM
Hugger's Avatar
You can get Centred Multi-Mile 165R/15's if you want the ones that can inflate to 44 psi. I will warn you... they are hard to find.
Old 02-23-2007, 02:35 PM
LS69TA's Avatar
I believe 165/80/15 is gonna be the right one.
Old 02-23-2007, 03:35 PM
Photochop's Avatar
Yeah just ordered some of those a few weeks ago, thats the right size, I think they were around $80 shipped for the pair from the rack
Old 02-23-2007, 10:41 PM
LS1_Disciple's Avatar
Not true...it's the aspect ratio. Scroll about half-way down - http://www.tirerack.com/tires/tirete....jsp?techid=46
Old 02-24-2007, 08:52 AM
LS69TA's Avatar
Yea...like these 165/80/15s. The sidewall is 80% as tall as the tire is wide (165).
Old 02-24-2007, 12:17 PM
dailydriver's Avatar
When a tire manufacturer does not give a profile number (i.e.; 165R 15) an 80 series profile is implied.
Old 02-25-2007, 12:44 AM
oange ss's Avatar
sidewall is 80% of the width of the tire...
165mm x 80% = 132mm x 2 = 264mm / 25.4" = 10.4" + 15 = 25.4" in. tire height...
Old 03-04-2007, 12:13 AM
boondiggys's Avatar
you are right!! just make sure your cheap tires are rated for the speed your going to abuse them to!
Old 03-06-2007, 08:29 AM
juiced_z28's Avatar
Most of them aint trappin over 118 anyway, lol. They are rated to 1201 lbs. per tire.
