LS6 intake swap
Old 02-23-2007, 03:28 PM
Travose21's Avatar
Default LS6 intake swap
what else do i need.
I brought the coolant lines is that all.
I have a 98 formula and all the that egr crap is off my car. what else do i need.
Old 02-23-2007, 03:33 PM
5_02ls1's Avatar
coolant lines and plugs
Old 02-23-2007, 03:50 PM
2001NBMZ28's Avatar
I'd install new intake gaskets...and take a look at the knock sensors for any signs of corrosion.
Old 02-23-2007, 06:24 PM
staringback05's Avatar
get the red gaskets if you can....they stick out a little more then the crappy grey ones...when you bolt the manifold down itll give you a better flush fit....no worries about leaking
Old 02-23-2007, 07:08 PM
JKDZ28's Avatar
Pipes and plugs.
And the manifold itself
Old 02-23-2007, 09:13 PM
arcticwhiteTA's Avatar
Red gaskets if you dont already have them, knock sensors and maybe even the wiring harness if you need it bad enough, and you should be set. It's really straight forward.
Old 02-24-2007, 09:05 AM
Travose21's Avatar
Default thanks
doing it today
Old 02-24-2007, 09:07 AM
Justin00SS's Avatar
I re-used the grey ones. No problems here.
Old 02-24-2007, 11:24 AM
wws699's Avatar
You will need the button head allen bolts for the valley cover (10ea) or the bottom of the intake will be resting on them and possibly cause your intake to leak.. Port and polish your throttle body also.....
https://ls1tech.com/forums/showpost....6&postcount=22
Old 02-24-2007, 11:49 AM
Sh4Dy's Avatar
Thats only with the FAST intake not the LS6.
