New Speed Inc. Twin Turbo 408ci dyno results
Old 02-23-2007, 06:01 PM
qqwqeqwrqwqtq's Avatar
Default New Speed Inc. Twin Turbo 408ci dyno results
We recently finished up another turbo car.
Engine is 408ci based off of a 6.0 iron block, patriot heads, LS6 intake, stock throttle body. Cam is 234/234 @.050 113lsa
Turbo system consists of truck manifolds, precision PT67 P-trim turbos, Tial 38mm wastegates and 50mm BOV. Dual 3in downpipes "Y'd" into single 4 inch to a magnaflow muffler. Hot side is ceramic coated, cold side is powdercoated.
Tuning was done with HP Tuners 3-bar OS. Fuel system is dual external walbros and RC 75lb high impedence injectors @66psi base pressure.
Dyno runs were made through a T400 trans and 12bolt rearend.
16psi boost- 826rwhp
18.5psi boost- 882rwhp
Engine was pulled to 7,350.
Old 02-23-2007, 06:04 PM
DeltaT's Avatar
Great fitment - very nice and sano.
Jim
Old 02-23-2007, 06:07 PM
cablebandit's Avatar
great numbers!!! Whos stall and what size? Thats a lotta power!!!!!!!
Senior Member
Country Boy's Avatar
Yall are top dog if money isnt an issue! Looks NICE!
Old 02-23-2007, 06:12 PM
Schantin's Avatar
Very nice. Like the "little differences", like the FPR directly off the rail. Those are some tight exhaust clearances too.
BTW, with all that boost (16+ PSI), is that on pump gas or race blend?
Old 02-23-2007, 06:19 PM
ls1muscle's Avatar
You guys have the best turbo setups
Old 02-23-2007, 06:21 PM
gator's 99TA's Avatar
now THAT is power under the curve!
Old 02-23-2007, 06:52 PM
obZidian's Avatar
right, ya'll are at it again!!
like it was asked before, would like to know more on gearing, stall, fuel type, and if those are locked numbers.
Im hoping to make similar numbers with my package. Got an s85 through a 408ci. 4l80e car.
good lob!! Oh, also, would ya'll happen to know what CR that motor is squeezed at? would love to see a vid of this car particularly...
Old 02-23-2007, 06:57 PM
Thanks guys.
Compression ratio is 8.8-1. Fuel is torco 110, total timing 18 degrees.
Converter is a TCT, not sure it's rating but I will find out, 3.42 gears, 275/40/17 et street radials. Dyno runs are unlocked.
Old 02-23-2007, 06:58 PM
SIK02SS's Avatar
excellent job!
Old 02-23-2007, 07:06 PM
99Z28LS1's Avatar
sweet car and sweet numbers, you guys never cease to amaze me
Old 02-23-2007, 07:17 PM
kp
kp's Avatar
Some pretty nice looking stuff as usual..
Old 02-23-2007, 07:24 PM
SSilverSSurfer's Avatar
is there a problem with the fuel lines being that close to the muffler?
car looks insane, and craftsmanship and attention to detail is awesome, keep up the good work
Old 02-23-2007, 07:31 PM
BigJls1's Avatar
awesome
One ? there was just a thread on th400 on the dynos
most everyone claimed that the th400 will read 100+ horsepower lower than a m6 or lockup tranny.
would a differnt tranny put you over 1000 hp.
if you had 1k hp .......................
traction=
Old 02-23-2007, 07:53 PM
Navy David SS's Avatar
Nice build. Great numbers. Hopefully he has suspension under there. He's got the power now to put it down to the ground.
On the dyno through T-400.. never have say anything about it, but I bet it varies a lot from one converter to another. An extra 100hp?????
Anyway great build
David
Old 02-23-2007, 08:05 PM
LS1 SPEED's Avatar
4,000 converter
The fuel lines are not close, but look that way due to camera angle.
The suspension is all there, just needs some work on rear quarters or a 27" tire to get back end down.
tracks open here in about a month
Old 02-23-2007, 08:21 PM
Jon @ Speed Inc's Avatar
This spring there will be plenty of cars that will be done and on the street. Counting the mustang's there are around 20+ custom turbo vehicles that have rolled out of our shop so far. Average horsepower in the mid 800's. Top dawg so far is still the Large Twin 408 with the 6 speed that did 1162 RWHP (STP on LS1tech). Sorry Shane, but I think we'll hit some bigger #'s this year by the looks of it
Old 02-23-2007, 08:29 PM
chasgiv3's Avatar
It's been my search for this type of power on a stock PCM. This is exactly what I've been searching for. The crew at SPEED INC. has really put the number crunching together on this. Picking the right parts to meet my goal. Keep in mind that it's a stock throttle body and an LS6 intake.
I'm really excited about running this beast at the track. The black coating REALLY looks awesome. I know that most people like a lot more chrome but for me I'm tired of seeing that. I like the monochromatic look so this REALLY looks great. Thanks to Larry at SPEED for suggesting the look.
It's been a long ride trying parts to make the number. Some told me that I was just crazy trying some of the stock parts that I did but it just shows the potential that these motors can make.
Dan, Jim (intmd8) and Larry great work and thanks for the effort on this. Tom's (owner) been a great friend for many years for me. I remember the street racing you used to do back when. You've come a long way baby!
Old 02-23-2007, 08:36 PM
Coal Mining Director
onfire's Avatar
Impressive through a T400. Y'all know turbos.
Old 02-23-2007, 08:38 PM
topend's Avatar
Are the turbos maxed out ????
Quick Reply: New Speed Inc. Twin Turbo 408ci dyno results
