1st time clutch bleeder needs some serious help
The clutch seemed fine but everyone said to bleed it just to be safe since I just had the motor & tranny out, so I did. After "burping" the system 2 times, now I have zero clutch. The resovoir is full with fluid and I saw some fluid dripping from the bellhousing. Now as I use my hand to pump the clutch, there isnt even fluid coming out of the bleeder. I appreciate any help.
by the way I have Mcloud adj. master cyl.
Originally Posted by blk00ss
Sounds like the steel braided line that goes from the master to the side of the tranny isnt tightened down all the way. From what I've read its fairly hard to get it threaded on good.
The only end I disconnected was the quick connect end.
Im wondering if I have air in the MC. Its wierd because the clutch seemed to be working fine and had pressure but I tried to bleed it since I installed a new motor and now I have absolutly zero pressure. man this sucks!
I would buy a mity vac. They are only 25 bucks at harbor freight.
Cut a short peice of 3/8" gas line to slide on the bleeder valve. Loosen it a half a turn. Hook up the vac pump to the little rubber hose and pump away.
It will fill up the clear cup on the vac pump with old fluid and pull the air out of the system.
I used it a few night ago after having my tranny out. My pedal feels great. I also put in a new slave.
Take the lid off the master, remove the black rubber expander seal and check the fluid level. Put just he cap back on, pump it a few times and re-check the level. Does it stay the same?
If you have the master out, try bleeding like this. http://mywebpages.comcast.net/buschm...utchbleed.html
ok I got the master cylinder back in and everything is hooked up. I filled the resorvior with fluid and now I got fluid coming out of the bleeder but the clutch has ZERO pressure still. any ideas??
Also even with the clutch having no pressure at all, I can still start the car. I thought that was strange.
