Dip Stick Quest. Again~
Old 02-25-2007, 04:15 PM
sickws698's Avatar
Default Dip Stick Quest. Again~
Okay, so i cant get my dipstick back in stilllllllll, ive used the search engine and everything and still cant find it, i was out there just a second ago and i was kinda jaming the dip stick down there so it would line up with the bolt whole and then somthing starting sparking. What would cause this, i take it i hit some sort of wire?
Old 02-25-2007, 04:18 PM
brad8266's Avatar
You probably hit the starter wire. The dipstick is do easy to put in, all you do is push into the hole and then bolt the top part to the head.
Old 02-25-2007, 04:21 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Disconnect the battery before you kill yourself...
Old 02-25-2007, 04:26 PM
sickws698's Avatar
lol ill do that rite now, but im about to go out there and still not have a clue, from where it bolts to the head, do i loook back towards the back of the car? or straight down?
Old 02-25-2007, 04:29 PM
MeentSS02's Avatar
Straight down.
Old 02-25-2007, 05:36 PM
Krab's Avatar
First, place the dipstick tube down between the header primaries, be sure your starter is removed so you can have more room to work with. Next, get under your car and feel for the end of the oil dipstick tube and the hole it will go into. Now, just try to guide the dipstick into the hole. Once it is aligned, get back up into the engine bay and just push the dipstick tube down until it seats. Now you can bolt down the dipstick to the head and you're done.
Old 02-25-2007, 06:52 PM
sickws698's Avatar
kk i got it, thanks guys. Only prob now is it isnt letting me bolt it in, so i gatta fiddle with it some more
Old 02-25-2007, 06:59 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Get a shorty from Lokar.
Old 02-25-2007, 07:13 PM
DuronClocker's Avatar
Had a Lokar on my old SBC. They look great, I've debated one for this car too.
Old 02-25-2007, 08:17 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
seriously. I have one on mine because I could not get it to bolt up to the head to save my life.
Old 02-25-2007, 08:20 PM
sickws698's Avatar
Wuts a lokar?
Old 02-25-2007, 08:39 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lokar is a brand. They make classic and hotrod stuff mostly.
Old 02-25-2007, 10:54 PM
That's what she said...
TheBlurLS1's Avatar
If you stand in just the will the right spot beside the fender and look through the A/C lines, wires, body, you can see the hole with a flashlight.
It is veddyveddy sneaky sir....
Old 02-25-2007, 11:02 PM
5_02ls1's Avatar
put some hair around the hole and spit on it lol
sorry coulnt resist
try wd 40 the rind is probably dry mine was a biatch to get out
+1 on starter removal
Old 02-25-2007, 11:03 PM
brad8266's Avatar
sorry coulnt resist
Old 02-25-2007, 11:14 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just cram it in there and turn.
Old 02-25-2007, 11:16 PM
BorgerTransAm's Avatar
lol It is a pain in the ***. Soo simple but still took me a good half an hour to do.
Chris
