Help on LS6 intake install
Hi, i am getting an ls6 intake soon and was wondering what else do i need to do the install. Also, could someone recomend a website that sells what i need. I am installing on a 1998 Z28.
Thanks a lot
Thanks a lot
Depending on what you are looking to do with your throttlebody should influence your decision on what kind of intake to use. If you go with a F.A.S.T. then you have to use their throttlebodies (they offer TB's from 80mm-90mm). I went with SLP because i wanted my engine to appear as stock as possible. I you decide to go with SLP and get a MAF sensor take the screen off to get a full 1000 CFM airflow vs 845. Since you are going through the pains of swapping intakes.....why not toss in a set of 1.7 or 1.8 ratio rocker arms too? just a thought
you can get the ls6 cooliant line and plugs from a gm dealr.heres what i done.remove the coolant lines using a pipe cutter and a double flaring tool cut the lines at each corner leaving enough for the flare get some hi temp/press 1/4" hose and make new ones.i wish i wouldve got pics before putting the intake on it looks as if it came from gm this way.you will save about 50 bucks by doing this
That's what she said...
Originally Posted by snake charmer
yeah i made my own coolant block offs from my original pipe and never had any problems . if you do have problems with it leaking it would be hard to notice on the back end since some or most would evaporate before hitting the ground .
http://i38.photobucket.com/albums/e1...f/IMG_1710.jpg
