Swapping 4.10's for 3.73's in a 10 bolt for longevity
I am considering removing my 4.10's and sticking in a set of 3.73's to soften the blow my rearend receives on launch. I never had a problem breaking gears until I installed them. I think the larger pinion gear and increased tooth contact will help the gears last longer. I know the ideal thing would be to install a 9" but it's not in the budget right now. My present gears are chewed to **** from exploding an auburn posi last summer, so they need to be replaced anyway, so would this be a good idea? I might add... I am installing a TR224 cam, FAST 78 intake, ported TB and LTs/ORY before the season starts, so my rear is going to be even more likely to break. I just want to know if I should stay with 4.10's or not. Opinions?
There's no way I would swap to 3.73s after having 4.10s, especially if your gonna have a cam. I have been running Motives for a while and they have taken some beatings. The weak link I have found so far has been the posi. I exploded it on the 1-2 shift. What brand gears have you been running?
Ha ha... well, that may be my problem too - been running cheapo $140 gearsets from the Auto Value store down from my house. I figured I wouldn't feel too bad breaking them if they were cheaper. Guess maybe I should try a set of good gears once and see what happens. Maybe stay away from the track until I get a rear in the car, lol.
Originally Posted by sidewayz28
where can you get gears "cryo and mikronited"?
