iron block 6.0 in camaro ss !!HELP!!
my friend and i just put a cast iron 6.0 in his camaro ss today, we used the ls1 heads and oil pan, has longtubes, chromoly pushrods, aftermarket cam. after we got it in today we hooked everything up we could find. at first it wasnt gettin fire but we found a crank sensor above the starter and plugged it up and it still wont start, it just backfires. but it is gettin fire. please give me some suggestions.
The cam sensor is only used for referencing TDC, nothing else. The crank reluctor is used for all the timing events (fuel and spark). And as stated, you need to retune it as the engine size is now more then the ECM expects.
Originally Posted by rklaw04
Does anyone know why it wont idle after being warmed up?
