Sponsored by: DashLynx
Those with McEwen gauge overlays ...
Old 03-04-2007, 06:22 AM
SnakeStomper's Avatar
Default Those with McEwen gauge overlays ...
(I did a search and didn't see this question)
Those that have the McEwen's ... how easy or difficult was it to install them? Any tips/tricks to watch out for? Thanks.
PS-this is not a thread to tell me why I should or shouldn't put these on LOL ... simply a question as to the difficulty of putting them on. Thanks in advance
Old 03-04-2007, 08:17 AM
99zee's Avatar
Not to difficult to put on. Its easier if you take off the steering wheel tilt lever. Other than that its pretty straight forward. I also used a T/A bezel when I put it back together.
Attached Thumbnails Those with McEwen gauge overlays ...-gagblk1.jpg   Those with McEwen gauge overlays ...-gaggone.jpg   Those with McEwen gauge overlays ...-gagslvr1.jpg   Those with McEwen gauge overlays ...-gagslvr2.jpg   Those with McEwen gauge overlays ...-gagslvr3.jpg
Old 03-04-2007, 09:15 AM
shawn's SS's Avatar
I put a small flashlight where the bulbs go, to illuminate the gauge as I was putting on the overlay. It was the only way I could get them lined up perfectly.
Old 03-04-2007, 01:02 PM
Looks great 99zee --- I still can't see how you don't have to remove the needles LOL just slip it on?
Thanks for the flashlight tip Shawn ...
Old 03-04-2007, 01:30 PM
Blacker's Avatar
The white face slips in behind the needles.
Old 03-04-2007, 01:43 PM
They do?? Is there like a slit in them I'm not seeing? LOL
Old 03-04-2007, 05:09 PM
jbuerke142's Avatar
they do, it's easy. make sure your hands are CLEAN
Old 03-04-2007, 09:23 PM
99zee's Avatar
The needle goes through the hole and the hole is covered by the black round "button" that the needle is connected to. Kinda hard to explain but makes since when you see the overlays. I don't have a picture of the overlays before they were installed. I'll see if I can find one.
Old 03-05-2007, 12:39 AM
How strong is the adhesive on these? Like if one corner sticks where it shouldn't how bad will it damage the overlay once I take it off to fix it? Sorry for the dumb questions
Old 03-05-2007, 08:41 AM
94blownz281's Avatar
i have had mine on since 97. but now the rpm,mph,temp needles stick on me?? i can tell the backing is sticking up. are maybe the bolts holding it to tight or did it come unstuck behind the backing?
Old 03-05-2007, 02:26 PM
99zee's Avatar
Its strong enough to hold them in place, but I wouldn't want to try and re-position them. Just take you time they will look fine. I started with the headlight panel then the a/c panel then onto the gauges.
Old 03-05-2007, 04:32 PM
ProjectCamaro's Avatar
Extremely easy to install.
Old 03-05-2007, 05:37 PM
ls2 bait's Avatar
adhesive is hella strong-dont let it touch until u have it where u want it because its a bastard to get back off without damaging it.
Old 03-05-2007, 09:56 PM
bob320fa's Avatar
I've seen a ton of posts where someone screwed up and it made me nervous but, it was so stupidly simple.......and I tend to screw up "do it yourself" projects.
Old 03-10-2007, 07:41 AM
CT ITALIAN 1's Avatar
the gauge overlay kit does not come with the HVAC and headlight overlays correct?
Old 03-10-2007, 07:46 AM
98WsSick's Avatar
i bought a chrome bezel for my t/a off ebay and i have to cut off the factory glass in order to install it. has anyone done this?
Old 03-10-2007, 08:08 AM
99zee's Avatar
l bought mine all together, but can't remember if it was a "kit". I think the other 2 pieces tie it together.
Old 03-10-2007, 11:22 AM
DisturbingDaPeaze's Avatar
it looks nice. but nicely expensive....
Old 03-10-2007, 12:30 PM
Tnhillbilly's Avatar
I just installed the McEwens last week, also the TA bezel! They look great! They were fairly easy to install, after you tilt the wheel remove the tilt lever, It gives more room to wiggle the cluster out. The worst part was removing the cluster, I had to really wiggle and pull to get it out of there. Also, the ac and heater overlays are a seperate item. Good luck!
Old 03-10-2007, 12:52 PM
thanks everyone! I should be receiving my overlays in about 3 days or so
Quick Reply: Those with McEwen gauge overlays ...
