AIR explanation
AIR explanation
AIR - Air Injection Recirculation - Emissions controll device. Injects fresh air into the exhaust gas before the cats. Helps them heat up to reach "emissions light off" faster.
Read this in the sticky, don't know what it means. Anyone help explain? thanks
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Cats will only operate/function properly when warm/hot. That is why you can't technically be legal with a long tube header. Heat dissipates the further away from the source it gets, therefore the cat is not brought up to temperature.
All AIR does is mix fresh air into the exhaust. I am assuming that it has a property that will make it hotter than just normal EGT (Exhaust Gas Temperature). Also gives you a cleaner burn...hence "emissions equipment".
The cat needs to be hot to burn up carbon, and to be able to clean up your exhaust output to be better for the environment.
Take your cats off your car, that's why we have trees!!
I didn't see your story in your post.. but if your asking how the Cat work.. I suggest you try Google'in it or Yahoo search it.
Here.. read this one
http://www.howstuffworks.com/catalytic-converter.htm
