What else do I need for my cam swap?
So far I have:
Parts:
Cam
Springs
Pushrods
Timing Chain
LS6 Oil Pump
Need:
Water Pump Gaskets
Tools:
Spring Compressor
Rods to hold up the cam
Balancer installation tool
I believe that's it. If anyone knows otherwise, let me know. I want to have everything sitting here ready when I tear into this thing.
Parts:
Cam
Springs
Pushrods
Timing Chain
LS6 Oil Pump
Need:
Water Pump Gaskets
Tools:
Spring Compressor
Just for right now, I am going with a used TR224 until I can buy a complete heads/cam combo. I didn't want to have to pull my heads to change lifters for use with a really aggressive cam. Not to mention I need a rearend before I buy heads. It should get my car solidly into the low 12's along with the LTs and FAST 78 I'm installing.
Get some engine assembly lube to smear all over the cam, some extra long bolts the same thread size as the 3 that thread into it so can make a "handle" to install the new cam into the engine. Also get some blue loctite for the rocker bolts and some gasket maker.
Good luck man, I look forward to checking out your car at the Power Tour this summer.
Originally Posted by Candyredz28
I'm going with the same cam, I hope i can get high 11's with a 2800-3200 stall and keep my 2.73 gears.
dont you think thats gonna feel kinda sloppy with 2.73 gears?
Originally Posted by slowtealz28
not to hijack, but does the 224 work with stock gears on 6-speeds?
here is my list:
TSP Cam Kit (cam, springs/retainers/seals/seats, pushrods)
LS2 chain
gasket set
Antifreeze
oil filter
Oil
Thread Locker
Thread Sealant
Permatex Ultra Copper
Brake Cleaner
valve spring compressor (tims tool)
3 claw puller
5/16 dowel rods
1/2 drive 24mm socket
1/2 drive Breaker bar
extra locks
Pulley installer (618hawk's tool)
comes out to $1005
LS2 chain
gasket set
Antifreeze
oil filter
Oil
Thread Locker
Thread Sealant
Brake Cleaner
3 claw puller
5/16 dowel rods
extra locks
comes out to $1005
