LS1 longblock 4 sale
it is being pulled out of my car in the next couple weeks. it has 30K miles on it. included is everything except covers and accessories. $1,500.00
~Guy (425)773-7076
~Guy (425)773-7076
the car and engine will be at Ellis's if interested you can pick it up there and once its there if you have any questions you can ask Ellis or just give me a call. like I said though everything is included oil pump timing assy heads cam everything except valve covers timing cover oil pan and external accessories. engine currently has 47 to 60 PSI of oil pressure and doesn't smoke. it is however getting blowby which tells me it needs piston rings. I'd slap forged pistons and rings in it and you got a fairly new engine for a steal. $1,500.00 30K miles on motor. no noises or anything like that. ~Guy (425)773 7076
damn at this rate I might as well build the **** out of this engine one piece at a time but then what would I put it in ........ would be nice to offset the cost of labor on the swap though..... yawn. .... bump ~Guy
I am upgrading because I want 650+ rwhp and I want it to run a long with that power. its starting to get blowby so I parked it and started buying parts. I was going to do a heads cam and forged engine next year but decided to do it this year when I started getting blowby. blowby = losing compression through the piston rings.(only noticed under boost) it still runs strong and you wouldn't know otherwise, but the engine only has 30K on it so if you put some forged pistons and rings in it thats all you would need for it to be like a new engine. or, for a measly 1500.00 run it for another 80K miles N/A. it doesnt smoke and no funny noises. Nata I havent had any bites yet so if you are interested I can take payments, let me know if you want to stop by to hear it run as it is still in the car right now. ~Guy 425 773 7076
