Stat comp vs. dyn com vs. cam specs?
Old 03-09-2007, 06:32 AM
Pray's Avatar
Default Stat comp vs. dyn com vs. cam specs?
I am going to build a 383 now for my 02 Z06 that my motor has three bad holes. I need to know what my static compression ratio is going to be with the following parts, and what size cam I am going to need to run to bring the dynamic compression ratio down to 8.6-7:1. I want this to be a bad azz daily driver slash street racer. I figured somthing in the high 230 to mid 240's at .050 would be a good cam.
Mod list.
AFR 205's 59cc
Eagle forged rotating assembly -2cc, 6.125, 4.00, 3.905
.40-.54 commetic head gasket? That is the real question. Which one?
LS6 intake and ported TB
ASP UD
Dynomaxx LT's
Borla cat back
I want to make close to 500rw if possible. Any suggestions would be appreciated.
Brett
Old 03-09-2007, 06:56 AM
brad8266's Avatar
https://ls1tech.com/forums/showthrea...&highlight=DCR
I have a 236/230 plugged in and the DCR is over 9. You could take a cam similar in size and retard it unpon install to bring the DCR down some and it will help the it to keep breathing up top longer. I would try to stick with a .045 or .040 gasket to keep a tighter quench area. I would also not go with anything smaller than a 236 sized cam since you have the 383 CI.
I also would not be running an LS6 intake and stock TB on it, you want 500HP easily you better get a FAST 90/90.
Old 03-09-2007, 07:54 AM
Pray's Avatar
Thanks for the link. It looks like I am going to be on the edge even with a large cam. I will post up the results that I cam up with when I have a minute.
Old 03-09-2007, 07:57 AM
brad8266's Avatar
You could also just go with the larger chambered AFR's and either mill them to acheive the results you want or adjust the cam timing. Besides with 59cc heads and a large cam your PTVC is going to become an issue. I would just go with the larger chamber heads.
Old 03-09-2007, 08:19 AM
Pray's Avatar
I am doing this on a shoe string budget right now. That is why there is no fast 90/90. I am kind of stuck with what I got. One of the options right now is a -7cc dish instead of the -2cc dish. I am not sure I want to run a cam as large as the 244/248 114+4 that it was going to take with the -2cc dish and a .054 gasket. I could also run that cam with 0 or +2 advance and knock the DCR down some more. I think I can get away with a 238/242 or so cam with a -7cc and .040 gasket. I am going to do a little more research and and post up all the specs and results and get some opinions from the forum members.
Old 03-09-2007, 08:20 AM
brad8266's Avatar
2 advance will bring DCR up, you want 2 retard to bring DCR. I would still look into the larger AFR chamberd heads.
Old 03-09-2007, 08:52 AM
Pray's Avatar
Thats what I meant. Going from a 114+4 to +2 or 0 lowered the DCR. So like you said retarding.
Old 03-09-2007, 10:07 AM
brad8266's Avatar
Oh ok, i see.
