Cam specs for my 418 what do you think i should do ?
Old 03-09-2007, 10:37 AM
Randy WS6's Avatar
Default Cam specs for my 418 what do you think i should do ?
Well i have this Crane Cam to go in my LS2 418 and i have a set of stage III Dart Pro1 cnc from Texas Speed with 2.100" int. 1.60" ext valves 58cc and 90/90 match ported intake and Stainless steel long tubs headers and the works to go with it .Crane told me the cam had 6* ground into it. I have a 2*up to 8* (+ or -) adjustable timing chain do i need to put it?
(dot to dot) for nitrous or pull some advance out of it with the timing chain. Here is the specs of the cam shaft.What would be the best all around performance or do i need a different cam shaft.
http://www.cranecams.com/?show=brows...tType=camshaft
Old 03-09-2007, 11:35 AM
LS1 Tech Administrator
Patrick G's Avatar
The intake lobe looks good from a duration and IVC standpoint, but the exhaust lobe is way too big for best performance on and off the spray. IMO, you're better off getting a different cam.
Based on the valve events, the cam is 250/266 .630/.630 112LSA +5
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-09-2007, 11:47 AM
Randy WS6's Avatar
What would you prefer for this setup with nitrous .and my heads have Comp Pro Mag 1.75 rockers arms and my valve springs are good for .660 lift
Old 03-09-2007, 12:02 PM
Patrick G's Avatar
Better performance NA and under a 200 shot: 250/256 .630/.630 111LSA +4
__________________
Old 03-09-2007, 12:05 PM
Randy WS6's Avatar
so with my 1.75" rockers the lift is a .648" .do you have this cam ?and my nitrous is a 200 shot.
Old 03-09-2007, 12:17 PM
Patrick G's Avatar
If you have this cam in hand, you can just install it dot to dot. It's not going to be bad, it's just that the exhaust is a little excessive based on the intake/exhaust ratio.
If you haven't ordered the cam yet, have Crane grind it with a little less exhaust duration. A 6 degree split is more appropriate than a 16 degree split IMO.
__________________
Old 03-09-2007, 12:32 PM
Randy WS6's Avatar
I have the cam but i want the best performace i can get out of this motor.
Old 03-09-2007, 06:28 PM
Randy WS6's Avatar
ttt...
