does anyone know what this connecter is?
i was asking about this one at the end my question about the vacuum line. but no one seems to know what this is. the cam sensor and crank sensor are plugged in and this one is kinda left over.
the wires are red-pink-brown w/ a white stripe
its this one right next to the coil harness plug
the ac hi pres switch is round, but thanks for playing our game, as a consilation prize you and a friend will recieve rice a roni, the san fransisco treat.
and after posting that i must infrom all who think im being an a$$, i do appreciate the help i was just being funny.
and while most 3 wire plugs do indeed go to sensors can't they also go to a switch, even though i cant think of one right now. the only reason i say this is most pink wires in this harness are 12 volts switched, i think?
Well if the cam and crank sensors are accounted for the only other 3 wire sensors that I can think of are the MAP and the MAF. I looked at the ones on mine but my MAF is the 5 wire one and my MAP has different wires going to it. Don't know if the wiring changes between the cars vs. the trucks but mine is from a truck. Hope it helps.
thank you guys. it is the cam sensor, and boy do i feel dumb. i just needed a visual and to give those of you who helped me i shall give you guys a visual.
i was sitting on my throne (taking a poop, told you i would give yas a visual) and was reading the newest issue of car craft and they are building an lq4 and mention something about having to raise the cam sensor to put the new cam in and they showed a picture.........
so i go check it i couldnt see it, but i felt it and it plugged right in. so, thanks guys for your help.
