whats my Comp.Ratio???
what info do u guys need to figure out my CR??
i got the LS6(243) unmilled, stock head gasket, and a torquer V.2.
ive looked for the comp. calc. but i cant get it to work.
also whats the stock CR??
Thanx guys
Thanx guys
Originally Posted by PREDATOR-Z
~ 10.67:1 SCR
Stock is ~ 10.1:1
Stock is ~ 10.1:1
MTI G-1 Cam .228/232 .585/575 on a 113 ?
Also do you think this would be a good match?
Your input is greatly appreciated.
Sorry for butting to your thread mcamarols1.
Originally Posted by 00T\A
Predator-Z What would be my SCR with the tfs 215's unmilled with the
What chamber size and what compressed gasket thickness. I assume on stock block.
Will be using GM MLS not sure of the thickness.
Same as above ~ 10.67 SCR, That is static not dynamic.
Sorry about that mcamarols1.
But it sounded like we were headed in the same direction so i hoped you would not mind.
I found this by doing a search.
https://ls1tech.com/forums/showthrea...dcr+calculator
