Those with scavenge pumps come in!
Just a few questions for those with oil return pumps. I have 1 for my twin set up as the turbos sit pretty low. Have you guys experienced any problems running your pumps? One of my worries is the pump dying and all my **** blowing up, lol. I would like to set up a light to it somehow so if it stops pumping, the light goes off..... any idea on how i can do this or if anyone has? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
jus get you a oil press switch thats a dummy light sensor.when its got no pressure it would ground a light and therefore giving you some piece of mind . you can either go aftermarket or cheapout and go to autoparts store and get a factory replacement sensor . thats my thought on the matter,hope it helps
ok thanks, ill try it.
How high above your turbo drain are you guys mounting your pumps? Like how far uphill does the oil travel to the pump?
__________________
lol yea, but id like to know right away so the turbos dont get damaged. I think one problem i may have is the pump being up too high for its liking. I'm going to lower it.
__________________
Trust me, you'll know when the pump stops working. lol And so will the rest of the county.
You ever been to the airshow? Your car will give giving off a plume of smoke similar to one of those jets.....
ok cool, thanks a lot guys, i think i have my pump mounted too high. Appreciate the help!
__________________
gravity, haha. i dont know of a best one, The STS one or the Gearstar that is the same thing are good. Also hear Mocal is good.
__________________
I had one of the wires short and man, did it smoke! I thought I had lost a turbo seal at first, but I had to get off the freeway and I went thru 6qts of oil in just a few minutes. The turbos seem to be fine, but I shut it down when I lost oil pressure (emptied the sump).
