need help with cam selection
Old 03-13-2007, 10:58 AM
JDP
JDP's Avatar
Default need help with cam selection
well since hopefully ill be putting the motor back together soon i want to get some ideas for a cam for my car, heres what its hopefully going to be and what i want.
6 speed car
ls1 10 over, stock crank, forged rods and piston
a set of AFRs if budget permits, fast 90mm intake, SD tune. stock wet sump oiling, and pump gas.
now the car is not a daily driver, just a weekend car/track car.
now im going all motor and im looking to make some good power up top, something thats going to make power at 7k+. i still want to keep the car a hydraulic roller. hopefully you cam gurus can show me the light at the end of the tunnel.
thanks guys, just trying to get some ideas together, would love to see the motor in the 500whp area, i know its possible.
Old 03-13-2007, 11:17 AM
chewy99ws6's Avatar
I would get a MS4, that is the cam I am looking at right now, I have a MS3 in my auto T/A and love it, that cams specs are I think 239/242/612/609 on either a 111 or 112 lsa, it will give you the power you want up high to about 7200, just make sure you have the vavletrain to back it up
Old 03-13-2007, 11:42 AM
JDP
JDP's Avatar
i was looking at the ms4, but im not sure if i want something a little more extreme, i also looked at the donkey dick which seems a little more extreme. im more than likely going to go with a custom grind for my setup, just trying to get the ideas before i jump into it
i would love to be damn close to that 500whp mark. i hope im not dreaming
Old 03-13-2007, 10:22 PM
JDP
JDP's Avatar
bump ttt
Old 03-14-2007, 11:47 AM
02 z/28's Avatar
donkey dick sounds good but I dont think it will clear with AFR heads.
Old 03-14-2007, 01:36 PM
JDP
JDP's Avatar
im not using stock pistons
Old 03-14-2007, 03:09 PM
ArrestMeRed99Z28's Avatar
Donkey Dick FTW!!!
Old 03-14-2007, 04:14 PM
tuffass's Avatar
Donkey Dick???
Must be a BIG Mother "F" er... lol....
Old 03-14-2007, 04:18 PM
JDP
JDP's Avatar
lots of lift, seems like a nice choice if you have a good set of flowing heads
Old 03-14-2007, 04:24 PM
PREDATOR-Z's Avatar
Gotta love the way Patrick called it
Old 03-14-2007, 04:29 PM
Vengence Vindicator wouldn't be a bad choice either. 240/244 @ .050 inch lift .6x lift 112lsa 108 icl. Some one just made 440 with stock heads and an LS6 intake, if you believe the dynos.
AJ
Old 03-14-2007, 05:30 PM
JDP
JDP's Avatar
so many choices, im not the smartest guy when it comes to cam selection, maybe patrick will chime in on this.
my goal will be around 500whp, i know i need to turn quite a bit of rpm to make that kind of power in a stock cube motor but im sure its doable. im not sure what ls1joe had in his H/C car but i heard he was turning that motor pretty high, on stock rod bolts too.
Old 03-15-2007, 01:53 PM
JDP
JDP's Avatar
im going to bump this to see if anyone else has an opinion
Old 03-15-2007, 07:24 PM
JDP
JDP's Avatar
errr, nobody else?
Old 03-15-2007, 10:18 PM
eamador11's Avatar
contact ECS and ask about the "500HP" custom cam they have. excellent top end cam.
Cam-only it puts down around 420rwhp. with its matching TFS heads, its very close to breaking 500rwhp.
Old 03-16-2007, 01:42 AM
99blancoSS's Avatar
Trex FTW
Old 03-16-2007, 01:33 PM
JDP
JDP's Avatar
Originally Posted by 99blancoSS
Trex FTW
i was waiting for somebody to say that, but to me a trex is only at .609/.612 lift which to me seems like it would be holding back a good set of heads, unless im wrong about this theory, which seems like it would be a great car for a cam only car with a lot of duration but with a good set of heads i feel like there would be better options because of the lift for a ***** to the wall 346 motor.
if im wrong about this statement, let me know
Old 03-16-2007, 04:38 PM
JDP
JDP's Avatar
my cam thread sucks, no debate in here
more than likely ill have patrick spec out a cam for me and ill have thunder grind it for me
Old 03-17-2007, 12:44 AM
PREDATOR-Z's Avatar
JDP, biggest is not best. Balanced is best. Match your components and with the right cam for the use of your car. Donkey dick and such are mostly track oriented.
For a balanced street setup such large durations are not needed. Patrick will vouch for that. You need the right compression with the right valve events for the flowing characteristics of your motor, whether intake to heads to exhaust.
Patrick will take ALL that info into consideration.
Old 03-17-2007, 09:51 AM
99blancoSS's Avatar
Take a look at the fastest cars list. Tell me how many trex' you see there. Thunders lobes make up for the supposed lack of lift.
And Pred is right about size and balance. trex is what 244/242?
You honestly need to do some research as well. All you've said was you want the biggest cam you can find. Its not a good plan. Re-think. Not much to debate when you just want a "donkey dick"
