moser 9" uses 4 bolts for torque arm?
got a moser 9" housing, can I use 4 grade 8 bolts and lock washers etc for the torque arm or do I have to stay with the factory 2 bolt setup? Only asking because the old bolts are rusty and nasty looking and I'd have to order the long ones and wait a week or so.
I believe on mine it was just the 2 bolts. I reused the stock bolts. I've had no issues with them backing off or anything either. I think some of the 4 bolt setups had some of those issues.
Only place online I've found new bolts is UMI and they state:
Note: This kit will not work with Moser Engineering rear-ends, you must reuse hardware supplied by Moser Engineering.
Is there any other shop that sells them? Or is this disclaimer just for the 12 bolt housing and not the 9"
I would think that would just be the 12 bolt. My 12 bolt uses 4 i believe 5/8" grade 8 bolts, but i thought the 9" uses the 2 bolt setup. I could be wrong. I wish mine had the 2 bolt setup. It seems like i alway have to tighten the torque arm down with lockwashers and red loctite.
Ryan
