Center console (upper piece that shows the gears)
Old 03-14-2007, 08:54 AM
Jeff 97 Formula's Avatar
Default Center console (upper piece that shows the gears)
How does this attach in the front? Asking because mine seems to be a little loose on the left side. Thanks
Old 03-14-2007, 08:57 AM
Shinigami2x4's Avatar
It just hooks under (might be above) the lower consel, there is not bolts up there. The side have clips and there is a "tounge" that goes into the glove box, and there are two screws under the coin holder there that hold that whole peice in (besides your shifter)
Old 03-14-2007, 09:15 AM
Right, I found the two bolts under the coin holder. The front (towards the driver side) seems a little loose. Is it normal or should it be snug with no play at all?
Old 03-14-2007, 02:42 PM
It should have a little play in it due to there is no retaining clips in the front. on the lower consel there is an "adjusting bolt" it has a sliding bolt, you can move that up and it should tighted up the gap and play in the upper consel.
Old 03-14-2007, 02:44 PM
That is located in the front under the dash near the pedels
