Center console (upper piece that shows the gears)
It just hooks under (might be above) the lower consel, there is not bolts up there. The side have clips and there is a "tounge" that goes into the glove box, and there are two screws under the coin holder there that hold that whole peice in (besides your shifter)
It should have a little play in it due to there is no retaining clips in the front. on the lower consel there is an "adjusting bolt" it has a sliding bolt, you can move that up and it should tighted up the gap and play in the upper consel.
