Sponsored by: CARiD
Popping noise under load
Old Mar 5, 2007 | 11:17 AM
fortmyerspolice's Avatar
Default Popping noise under load
Recently I changed the plugs and wires. Under heavy load I get a popping noise under the car, think its the exhaust. Seems like its a misfire. How can I tell which cylinder it is?
Old Mar 6, 2007 | 10:46 PM
sdm1234's Avatar
does it buck under acceleration? do u get an SES light? if it was a misfire, you would probably be getting one of those. maybe a manifold/header gasket leak.
Old Mar 7, 2007 | 05:45 AM
yes it bucks. no i dont get an ses light.
Old Mar 7, 2007 | 11:53 AM
jeff2380's Avatar
the SES light flashes when the engine is misfireing and throws code P0300.
Old Mar 7, 2007 | 05:28 PM
so what do you think it could be
Old Mar 8, 2007 | 02:40 PM
ttt
Old Mar 8, 2007 | 02:49 PM
TheLS1Kid's Avatar
Maybe you cracked a spark plug putting them in. I did that on my old 96 RS 3.8l and it didnt throw a code. I went crazy for months thinking it was my trans slipping and then i finally checked the plugs. Its worth a shot to check.
Old Mar 8, 2007 | 09:05 PM
ghardester's Avatar
When you changed the plugs did you move the AIR tubes for better access? If so, did you use new gaskets? Cause if you don't you can get a sound from a leak there.
Old Mar 9, 2007 | 10:49 AM
krayzie7th's Avatar
Make sure u didnt cut a wire or made a little slice one of them because they can be arcking to another wire at heavy load.
Old Mar 9, 2007 | 03:22 PM
I did take the AIR tube off, but if it was that wouldnt it be making it constant?
I dont know if i cracked one or not but how can i pinpoint it?
Old Mar 9, 2007 | 08:15 PM
ghardester's Avatar
You are right. If it was the AIR gasket you can hear it at idle. I missed what you said about under a load.
Old Mar 10, 2007 | 07:04 AM
Im going to take each sparkplug out and see whats going on
BTW would an o2 sensor do this?
Old Mar 10, 2007 | 09:46 AM
TheLS1Kid's Avatar
I dont think so. A bad o2 sensor will just give you crappy gas mileage and an SES light.
Old Mar 11, 2007 | 10:35 PM
3.4camaro's Avatar
pull out 1 plug at a time. during this, your fingers will become dirty and greasy. Rub your fingers on the ceramic part of the plug and look for black lines on the white ceramic part. If theres a small crack it will show black because of the grease.
Old Mar 11, 2007 | 10:51 PM
Roadhouse's Avatar
The popping sound could be one of the spark plugs that has backed out and letting compression get by. Make sure all the plugs are snugged, wires are pushed in fully and AIR connections are tight. Sometimes when nuts n bolts get hot then cold and hot a few times, they loosen up.
Old Mar 12, 2007 | 11:42 AM
I bought 4 NGK tr55's and gapped them to .55 I replaced the drivers side and it still pops. I also saw some of the plugs i pulled had oil on the threads. I'll continue to replace the other 3 on passengers.( I replaced #8 when the popping noise was going on, so its not 8)
Old Mar 14, 2007 | 03:35 PM
Just changed the plugs. Its fine now but I think one of the coil plugs was loose, I jiggled it and now it works great. For anyone having the same problem as I, Make sure all plug connections and coil connections are secure!
