'00 TA Just Bought Unsure of exhaust to get
Just bought a '00 TA last week this is going to be my first car modding ive been looking around for exhaust and reading forums but i need a little advice so far all im considering is a set of pace setter headers new y-pipe and slp loudmouth or borla any suggestions? trying to keep cost low...
also any suggestions about some tires to put on the rear end? need new ones badly...
thanks
thanks
Sounds like you are on the right track so far. I would vote for the borla unless you want a real loud set up. Hooker also makes a pretty decent cat back for a pretty decent price. I dont know if the headers will be coated but I would get them ceramic coated. Tires... not cheap but Goodyear GS-D3 are pretty awesome and u might want to look into KDWs
save the money and get the good stainless steel headers get the y-pipe made specifically for you and what fits underneath, the exh all depends on how loud you want it what your planning on doin with your car you dont wanna be buying different exh's , what tires are you looking for drag radials or regular tires id say drag radials go with m/t regular tires go bfgoodrich kdws
You cant really go wrong with a 3" Y and a trusted catback, but I say look around, you might be able to find a shop that'll fab you up duals for about the same price as a catback. If you decide to get duals you'd also have to buy mufflers, but mufflers alone aren't expensive.
thanks for the help i was considering the TDs but i need to find out how much that is vs. not having them and with the cat back system i was told i would get better performance from the slp instead of the borla (also half the cost of borla)...and then another thing, a set of headers ( which i would get coated) are they really going to do much a difference...heard they wouldnt?
almost every cat back out there for f-bodies that have longtubes and ORY sound like **** in my opinion cause of the rasp.....now that i have my td's installed, it soundsss sooooo muchh better....i wish i woulda done this from the beginning
my LT, ORY, Flowmaster did not rasp, but it also didn't flow very well. You can have a true dual system built for a similar price. I never got my car on a dyno So I can't give you a comparison, but the car trapped 105mph in the 1/4 with the flowmaster, I'll revisit the track in the next month or two to see what I picked up with true duals.
AJ
AJ
yea other people are suggesting true duals im looking to spend around a G note i just want to get the most bang for my buck...anyone know of a good shop near chicago that can do the TDs at a reasonable price?...
thanks
thanks
Get stainless headers and check out http://www.ls1sounds.com
Take you're time and really think about what you want to do with the car.
