How will big cam respond to boost?
1 Post
I have a torquer v3 in my car with all the supporting modifications.
231/234 .644/.598 111lsa. How would this cam respond to say 7-8 psi? I know that people generally like lower tame cams for turbos but I was just wondering exactly how it would go?
That cam has a bit more overlap than you would want for a turbo setup. It would run fine, you would just lose some power due to boost bleed-off. There are more "efficient" cams out there for turbos.
LS1Tech Sponsor
Originally Posted by engineermike
I don't think anyone has actually proven that. In every test I've seen, quite the opposite turned out to be true.
You'll see what I mean if it was a supercharger with boost controlled by a belt. Stock cam with 8lb pulley would make 8 lbs of boost.With the cam listed above boost would probly be 1-2lbs with the same pulley.Power would be about the same but the stock cam will have more throttle response.
So,my answer is why not put in a better turbo friendly cam? You spend all the $$ on a turbo setup but want a bad cam for the application. In the end the T3 just isn't efficient for a turbo compared to what is out there.
1 Post
Ok thanks for the info. I was just curious, this would be next winter's project if anything. I am into trying new stuff too so i might give it a shot and if i dont like it... pfft cam swaps easy and now that i got all the supporting stuff it wouldnt cost too much.
That's not necessarly true. When you install a larger cam, it will make less boost, but more power. This has been proven many times. Now, with a turbo, you install a larger cam, then boost holds the same because the boost controller and wastegate automatically adjust. Then you make even more power.
Again, I don't think anyone has proven that his 231/234-111 is actually a bad cam.
In theory!
LS1Tech Sponsor
A more friendly boost Cam WILL make more midrange power than the cam listed.Will the cam listed work? Yes,any cam will pretty much work.
Do I have to prove it? No ,because I've already tested this stuff and proved to myself what I'm saying
I would only recommend the Cam above if the static compression is high.The lower DCR will benefit the boost.
. . .I ran a similar Cam on a blower car that was built NA,then added a blower.It made the same peak but lost midrange power with the low boost which the Cam bled off.
For a turbo car, in the tests I've seen, every time overlap is added, they make more power. Keep in mind that totally different things are going on during overlap with a blower and a turbo.
Mike
What convenient timing!
https://ls1tech.com/forums/forced-induction/678711-my-04-gto-76mm-set-up.html
346 LS1, 232/234-112 cam, 6 psi boost from a T76, ~640 rwhp.
https://ls1tech.com/forums/showthread.php?t=678711
I vote for using the cam.. also some of the best Ford turbo tuners use cams clost to this set up
would the larger cam(although possibly flowing the same amount of air, and making the same amount of power) at a lower "boost guage reading" help to reduce the chance of getting detonation? or is detonation more based solely on total airflow going through the engine and actual AFR?
The Torquer is not a good turbo cam due to overlap and reversion, remember exhaust is what drives turbos. That cam will work just fine with a blower though. I may be installing a procharger on my head/232/236 112 cammed car.
