a lot of water out of exhaust
Old 03-19-2007, 08:16 PM
bowtierodder's Avatar
Default a lot of water out of exhaust
just did my ms4 swap and im getting a some of what seems to be water out of the exhaust, is this normal? didnt have this before swap
Old 03-19-2007, 08:59 PM
blkbird's Avatar
Do you smell coolant? Have you had to add coolant in the radiator? It could just be the condensation inside the exhaust. My car does this in the mornings while its warming up.
Old 03-19-2007, 09:28 PM
the exhaust gas smells like its running real rich, the the water substance doesnt smell like anything, but water
Old 03-19-2007, 09:32 PM
blkbird's Avatar
Take it for a drive keeping an eye on the temp. Then check to see if you are still "leaking".
Old 03-19-2007, 10:37 PM
SSNISTR's Avatar
Seems normal to me after a cold start....
Old 03-19-2007, 10:50 PM
styoung's Avatar
its just condsation(cant spell worth the ****) in the pipes, i wouldnt worry about it.
Old 03-19-2007, 11:08 PM
cool thanks guys
Old 03-29-2007, 08:24 AM
T'sBlack99Z28's Avatar
I was just gonna ask the same question. I just installed the G5X4 ( just a tid bit bigger then the ms4) and just I start it up in the morning it spits some water out but once warmed up it doesn't at idle. But from what you are saying this is totaly normal?
Old 03-29-2007, 08:39 AM
blkbird's Avatar
Yes....
Old 03-29-2007, 08:41 AM
brad8266's Avatar
Its just water condensation in the exhaust dont sweat it. Mine did it too and to test it I tasted it, tasted like plain ole water with a hint of exhaust. And it was just as clkear as tap water too.
Old 03-29-2007, 08:43 AM
brad8266's Avatar
Your exhaust will smell "rich" no matter what if you dont have cats. I can lean mine out to 18.0 AFR and it still smells, it just part of running no cats.
