Mondblade
Old 03-20-2007, 12:47 PM
JUICED96Z
Guest
Posts: n/a
Default Mondblade
Who makes them still? Could not find it on TPIS's site or Airizona S&M????
How much CUI and power can a Holley 58MM TB handle?
Old 03-20-2007, 01:07 PM
-PEPE-'s Avatar
Hmm...call ASM dude they still make them, where I got mine last Sep, unless they quit. You'll get a ton of opinions but very vew have actually benchmarked with a dyno what it's capable of. Therefore on average from being on here 5 yrs or so I'm estimating a 58mm would suffice for well over 700+ and the mono would probably do a little better maybe. Only reason I bought an ASM was I was using a loanerand knowing a SuperVic was in the works it made sense longterm.
Old 03-20-2007, 01:14 PM
JUICED96Z
Guest
Posts: n/a
Well I am looking at a big inch small block and 900crank HP this year.
Old 03-20-2007, 02:18 PM
plaf713's Avatar
http://cgi.ebay.com/ebaymotors/92-97...QQcmdZViewItem
Old 03-20-2007, 05:24 PM
jldak318's Avatar
^^^^^^^^^^^^^^^^thats not an as&m, as&m has offset t/b plate holes and has only 3 butterfly screws if im not mistaken. looks like a machined stocker to me.
Old 03-20-2007, 05:45 PM
Captainofiron's Avatar
yea its a fake, looks pretty interesting though, here is the real deal
heres the link
http://www.azspeed-marine.com/58mmmothbo.html
Old 03-20-2007, 06:58 PM
-PEPE-'s Avatar
heres the link
this is one fine piece of art, after 3 brand new Holley 58mm's (all warrantied) they would stick due to their design flaw which supposedly was fixed but wasn't. I've never had any issues with the ASM.
Old 03-20-2007, 07:17 PM
T/A KID's Avatar
Pepe where did you drill your 1/8 hole for that thing to Idle right??
I need to do mine before we assemble the motor
Old 03-20-2007, 07:38 PM
-PEPE-'s Avatar
You know I need to check, I don't remember now if we did or not, seems like we did, I'll check when I head out there in a few minutes, if I did it would have been logically at the bottom center closer to to the IAC motor.
Old 03-20-2007, 08:59 PM
1989GTA's Avatar
Regarding the monoblade on a LT1 motor I have heard a few theories. One is with the monoblade the air is slower going through the throtte body and is better able to make the turn into the front runners. This results in better air distribution.
Another is it increases the plenum volume somewhat and the LT1 plenum needs more cubic inches. The third is that atmospheric pressure replenishes the air in the plenum and the least restriction posible is best.
I know the "Air Doctor" here in Southern California pushes the monoblade for the LT1 based on his dyno results.
Old 03-20-2007, 09:08 PM
TwoFast4Lv's Avatar
I have a New AS&M Mono to go on my Hogans 18* intake. I also have a new Nitro Daves Mono plate kit coming for the Second or third stage
BTW playing with EA3.3 it was worth 30+ HP over a 58mm in sim's
Old 03-20-2007, 10:27 PM
-PEPE-'s Avatar
Ok it's exactly where in the middle about a 1/4" from the bottom center. Not quite an 1/8" hole I don't think but close, tiny bit smaller maybe.
Old 03-20-2007, 10:43 PM
1989GTA's Avatar
Hehehehe. You have a lot stronger motor than I'm running. On DynoSim mine only shows a 6hp increase over the 58mm throtte body. However if I knew for sure I could get 6hp I would go for it.
Regarding the hole in the throttle blade. If you start out small you can always increase it if need be. Harder to make the hole smaller.
Old 03-20-2007, 11:16 PM
TwoFast4Lv's Avatar
I found it was the restriction at 6,700-7,000. After switching from 1000CFM(58mm) to just 1250CFM(50CFM less then Mono is usually rated) I lost the restriction and picked up power through the curve. The sims were running in the mid to high 600hp range with a small solid roller.
Old 03-20-2007, 11:18 PM
-PEPE-'s Avatar
no ****? Funny when I ditched the Holly POS 58, I lost about 6hp and figured it was the humidity, really bad 100 deg day and massive rain that morning, miserably humid, shrugs....I'm hoping with this new SR cam and a SuperVic it'll just blow my old 500rwhp away and shine, we'll see. Thanks for sharing that, cool you benchmarked the difference.
Old 03-20-2007, 11:24 PM
TwoFast4Lv's Avatar
Do not put to much stock in it till you personaly test it Brett You have to remember I am the idiot who dyno's a 24 RWHP differance from a 48mm to a 58mm back in 2001
This was also JUST a computer sim on EA3.3
Old 03-20-2007, 11:31 PM
-PEPE-'s Avatar
True true, well like I said I had to buy one, had a loaner and when she was almost built last July, had to break out the cash so it made sense I guess. We'll see. I'm toying with the idea of a 4-bl 1550cfm TB on the SuperVic ...if that don't work I'll try a F*&^ing 4-bl 1050 Race Demon... ...whatever works...I'm going to find something that works right...
Old 03-20-2007, 11:48 PM
TwoFast4Lv's Avatar
I hear you man! I have had this 18* setup laying around for to long. it IS going to get used!
I mean Come on if you had a very $$$$ Hogans laying around that would make TONS of HP would you want to use it
Old 03-20-2007, 11:51 PM
-PEPE-'s Avatar
Yeah man! Whatcha waiting for bro??? Do it...just do it...do it! (Starsky & Hutch)...
Old 03-21-2007, 12:22 AM
JUICED96Z
Guest
Posts: n/a
What do you have to modify and do since the linkage parts are on the other side????
