edelbrock or pacesetter
i've finally figured out my full exhaust but wanted some opinions on either edelbrock or pacesetter lt's. i kind of want the edelbrocks but they end up 3.5 inches and my dual pipes are 3 inches
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Edelbrock LT's COATED ...very nice headers....BTW..your 3" pipe will fit into the 3-1/2" headers ...use some band clamps and some tin foil around where the pipes meet.....
I'll throw another one in for Edelbrock. Doing the install right now. They look solid. I know it doesn't apply to you, but their Y pipe is the best I have seen for the money.
Only downside, I ordered mine Feb 5th and they arrived 5 weeks later. Edelbrock isn't making a whole bunch of them, so the wait just depends on when you order.
They are both really good headers, the Pacesetters are made well and the price is right. I have them and they're great so far. The Edelbrocks look awesome and are becoming very popular also. You will need to use reducers to mate them to your pipes. Depending on what your long term goals are, you will see pretty much the same performance out of either set.
Originally Posted by V6 Bird
Negative on power boss. You will make more in any given situation in the curve with the E-brock stepped header and race style collectors they offer.
I don't disagree with you, but how much more? I understand that the power gain will be greater as supporting mods increase, thats why I added that it depends on what his long term goals are.
When I was cam only I swapped from Hooker headers, 3" duals with X pipe and twister mufflers to E-brocks, 3.5" duals with Twister mufflers and netted 40rwhp all over the curve.
Even in the beginning you will net on average 10rwhp increase in midrange power.
I just installed a set of Pacesetters that are jethot coated INSIDE and OUT!!,through maryland speed, who are a sponsor for a good price!!! and they carry a life time warranty!! I had no problems w/the install they slipped right up, no cutting of the k-member, heat shields, or the BLOCK TABS!!, the car sounds awesome and I can really feel it on the highway in the upper range. Next up, a good tune from speedinc, YOU Hear that Speedinc!!!!, "i'm coming".
Originally Posted by GR33N GoblinM6
unless you buy those stainless ebay headers.. people cut the tabs off for those.
