handheld capabilities ?
Old 03-20-2007, 07:05 PM
ksk1980's Avatar
Question handheld capabilities ?
will any of the hand held programmers delete out the codes for the egr and smog . any suggestions on programmer name brands as far as ease of use and total hp gain and total capabilities need programmer for '02 ws6 m6
Old 03-20-2007, 09:56 PM
CW00BlackTA's Avatar
Had a Predator. Have HPTuners. Wouldn't ever go back. There is a learning curve but the extra money is well worth it.
My opinion.
Old 03-23-2007, 08:05 PM
SLPSS01's Avatar
To answer your question it will show and clear DTC codes but
you can't disable the rear o2's, egr, etc..which is what I believe you are asking? The only way to do it with a handheld, like a Predator, would be in conjunction with custom tuning.
Old 03-24-2007, 12:46 PM
2001NBMZ28's Avatar
The latest Predators can permanently turn off AIR, EGR and rear 02 codes.
Old 03-24-2007, 01:27 PM
On the tree
Sneakyws6's Avatar
Yep, the Predator can do all of that as long as it has the newest firmware in it.
I am using it on my Formula and it does almost everything you would need it to do plus Diablo is working on a laptop tuning suite to work in junction with the Predator.
Old 03-24-2007, 06:25 PM
SLPSS01's Avatar
I apologize. I have an older unit and have not kept up with the latest.
That's pretty nice they have added those features.
Old 03-24-2007, 06:41 PM
2001NBMZ28's Avatar
If you have a purchase receipt the upgrade is free.
Old 03-24-2007, 09:47 PM
mrr23's Avatar
the vinci tuner will turn off EGR and AIR, but leave on EVAP stuff.
Old 03-24-2007, 09:52 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
where????? you must mean it sets the parameters far enough off---no.???
Old 03-24-2007, 10:56 PM
mrr23's Avatar
when you use any of the preset tunes, this stuff is automatically done. you cannot independantly do it.
Old 03-25-2007, 08:54 AM
On the tree
Sneakyws6's Avatar
Incorrect answer...
The Diablo Predator as long as the unit has received the new firmware update or it is a new unit can delete the codes individually.
Old 03-25-2007, 12:45 PM
mrr23's Avatar
Originally Posted by Sneakyws6
Incorrect answer...
if i was talking about the diablosport, then yes, i would've been incorrect. but, if you'll take a closer look, i said the vinci tuner does it with the preset tunes. so, in that respect, i am correct.
Old 03-25-2007, 12:49 PM
NHRAMAN's Avatar
Thumbs up
Old 03-25-2007, 12:54 PM
mrr23's Avatar
which was made to answer you about what the vinci tuner does, of which you quoted me where i said vinci tuner. so, yep ,talking about the vinci tuner.
