Large Cam'd LS1's: Can they cold start and drive immediately?
Old 03-21-2007, 12:02 PM
808ws6's Avatar
Default Large Cam'd LS1's: Can they cold start and drive immediately?
I have a general question regarding large cam'd LS1's.
I have an MS4 cam'd LS1 with a 6 speed.
Is it possible to get the engine tuned so that it can be immediately driven after a cold start without stalling?
I remember 'ol days of pulling the choke which would raise the idle speed and fatten the mixture enough to make the car driveable when cold.
TIA
Old 03-21-2007, 12:04 PM
beardWS6's Avatar
We are SD tuning mine for better daily driving. With big cams like mine and others its tough. Autos are really tough!
Old 03-21-2007, 12:26 PM
Man-Crush Warning
01sscam's Avatar
My MS4 takes a while to catch an idle in the cold.
Old 03-21-2007, 12:31 PM
12secSS's Avatar
Depends how cold we are talking about here. Here is So-Cal, I recently helped out a fellow enthusiast with his T-Rex'ed SS, I adjusted a few tables prior to start up. It had not been fired up that day. He started the car and it held idle decently, enough to move it around. That was before any tuning. It can be done.
Old 03-21-2007, 12:54 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Yeah I am sure its possible cause its all in the tune. I really would not count on it though cause thats a damn big cam.
Old 03-21-2007, 01:01 PM
LS1 Tech Administrator
Patrick G's Avatar
I've tuned several stock displacement cars with T-Rex cams. While it takes a lot of data logging, it's possible to get them to have very good cold start manners and low rpm drivability. Adjusting the VE tables and running airflow tables are key to making it happen. Without hitting those tables, your open loop fueling will be off and your drivability will suffer.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-21-2007, 01:14 PM
ibanez7's Avatar
regardless of a cam or the car. I always let a cold engine warm up before driving
Old 03-21-2007, 01:24 PM
LS1Formulation's Avatar
Wouldn't it be a smart idea to get a little heat in the valvesprings before driving? Just seems like it would be a good idea with a cam that large.
Old 03-21-2007, 03:54 PM
808ws6's Avatar
Thanks for all the replies and inputs.
I figured it is the drawback of using a large cam.
It gets to low 60's where I live in the morning.
I knew I was going to get flamed about the driving when cold part, but I am not driving it any faster in engine speed, just moving the car (I live in a association with pain in the *** neighbors).
I'll try some more VE enrichening at cold temps and Desired airflow adjustments.
What table in EFI Live do I specifically change for cold start VE? And what desired airflow is too much for start-up? I am running a 16.2 g/sec airflow at 20 deg c. now.
Thanks!
Old 03-21-2007, 04:55 PM
tilly's Avatar
how about 20s or 30s? I am just throwing this out there.
Old 03-21-2007, 05:10 PM
c0ncEpT's Avatar
I have friend with a Stalled MS3 car and on a cold(60) morning he HAS to let it run for a min or to or it will die the second he puts it into gear. but after a min or 2 of it running even if the needle isn't off the bottom it will drive just fine
Old 03-21-2007, 05:12 PM
Patrick G's Avatar
Regardless of temperature, it's possible to have good cold start manners with the right tune. Nailing the VE tables, Open Loop fueling tables and running airflow tables are the keys. Not something you'll typically get with a mail order tune or a 30 minute dyno tune. Tuners would go out of business charging only $500 for the kind of tune necessary to give these kind of street manners. It takes HOURS of data logging to do it right. If you can find someone who will do it right for $500 or less, pay them the money...otherwise, put those funds to buying your own programmer and have fun perfecting the tune yourself!
__________________
Old 03-21-2007, 07:55 PM
yekta's Avatar
I don't know if my cam is too big but with a good tune now it almost never dies on me unless if the AC is on when I started
Old 03-21-2007, 07:59 PM
SSpdDmon's Avatar
Is it possible? Yes.
Would I do it? No.
Why not? I don't like valve spring swaps and I'd rather not risk having another spring break on me.
Old 03-21-2007, 08:24 PM
yekta's Avatar
Would I do it? No.
good call, those are such pain!
Old 03-21-2007, 09:02 PM
beardWS6's Avatar
Do it right and don`t go cheap. You shouldn`t have this problem!
Old 03-21-2007, 09:04 PM
98Birdie's Avatar
I have the ls1 hotcam without being tuned and it runs good but cold it surges for about a minute and then idles. But, I have to still feather it ti keep it from stalling with the manual when it is cold. It is a bitch on my sloped driveway.
Old 03-22-2007, 12:49 AM
cowboysfan's Avatar
I wouldn't do it! drive when it's a cols motor. for one aluminum takes awhile to expand (piston slap) and v-springs are cold. just dont like the sound of this but, it's ur car you do it right (good tune, let it warm up before u stomp on it) should be no problem....................
fuerzaws6
Old 03-22-2007, 03:22 AM
WS6Drop's Avatar
Mine hunts for a little bit then settles down. I have to hold the gas pedal down a little when I start it to catch idle. My idle tune isnt very good.
Old 03-22-2007, 08:05 AM
marv's Avatar
With my old setup, it caught an idle just fine...however with the new heads, this time around it wants to hunt around and surge a bit....but only for 20-30 seconds, then it does fine...
Still give it a few minutes to get some heat in the springs though....
Quick Reply: Large Cam'd LS1's: Can they cold start and drive immediately?
