Sponsored by: DashLynx
Stupid question on decals
Old 03-24-2007, 11:20 AM
Alpha-Q's Avatar
Default Stupid question on decals
How do you put on camaro decals? you need like a hair dryer or something?
I keep getting air bubbles when i try.
Old 03-24-2007, 12:22 PM
98MNBZ28's Avatar
my girlfriend did mine on my last camaro,all she did was wet the area,applied decal,and squeegie(not sure if spelled correctly) out air bubbles,she rocks
Old 03-24-2007, 12:56 PM
Alpha-Q's Avatar
How did she use a squeegie?
Old 03-24-2007, 12:58 PM
1meantransam's Avatar
what decal are you talking about?
Old 03-24-2007, 01:02 PM
FireBreathingChicken's Avatar
Whenever I have applied decals I clean off the area first and dry it. Then I re-wet the area with a spray water bottle and spray that back side of the decal that will be sticking to the car. The reason I keep it wet is so it is easier to slide and reposition in case I mess up. After the decal is in the proper spot I use a blow dryer and press on the decal which helps to get rid of the bubbles. Hope this helps a bit.
Old 03-24-2007, 02:10 PM
Zymosis's Avatar
What about a small soapy + water combination, that helps you slide it around and get it right. Then press the decal from out to in. You can use like a credit card or something small and flat to work the bubbles from inside to out.
Old 03-24-2007, 02:46 PM
shiv15's Avatar
Yeah, Brent's site has the install instructions for decals. He says to use 1 drop of soap mixed with water. Just don't use too much soap beacuse it takes forever to dry from what I hear.
Me personally, I said F it and just went at it completely dry my first shot and it came out pretty good.
Old 03-24-2007, 03:34 PM
Alpha-Q's Avatar
i just fucked up on mine and now i need some new ones.
Old 03-24-2007, 03:56 PM
shiv15's Avatar
oh well atleast they aren't expensive.
Cld069's Avatar
If you have a small bubble here or there you can just take a pin and pop it. Thats what I had to do on one of my decals and it wasnt noticeable. Other than that Id go with a touch of soap and some water in a bottle. Thats what the directions told me to use if I didnt buy their "solution". Once you get them on try and let it sit out in the sun for a few hours.
Old 03-24-2007, 07:10 PM
arenberg13's Avatar
^^ he is right
Old 03-24-2007, 07:21 PM
lomaximumta's Avatar
Originally Posted by arenberg13
^^ he is right
my wife did mine and she did the same thing.
Old 03-24-2007, 09:14 PM
ghardester's Avatar
Soapy water deadens the glue on vinyl decals so you can move them a bit. Did that the first time I put some on. Last time I bought the 'glide on' goop from phonixgraphics.com with the decal. It didn't really work any better than a little soapy water in a spray bottle.
