My good luck has ran out...
Last weekend during the Supra nationals I was beating on the car HARD... and boost maybe running a little higher then usual lol and I noticed the car sliding a little bit on a top end pull, then it proceeded to run a little hotter babied it home to find coolant sprayed all over under the hood. Overflow tank looked like a M-80 went off inside of it
I let it sit all week and confirmed today. I did a little experimenting to make sure it wasn't knock causing it, sure enough no knock was seen and it still lifts the heads. Time to tear it down. I guess I can't complain about a solid year of beatings it took at that level. The damn 346 from hell is still kickin though... gotta make up my mind if I pull it out now for a refresh or just swap gaskets......
Was fun though
Was fun though
Originally Posted by kp
I never had any problems like that with 18-20psi on pump gas.
Sorry, had to
Sorry, had to
LOL you know better then that
I was runnign VP109 and 18-20 psi at ~1000 rwhp. It has always been a matter of time
Originally Posted by lbz34
C-16 Ftw
what for? it had no knock at ~18 deg of timing .
O2s would die
WG's would die
need to revise soem **** to convert over, and there is no point unless I want to turn it up higher which I will now.
Actually my sensors are two years old and C-16 or sunoco supreme (112 R+M/2)hasnt kiiled them yet. That shitty track-tech and turbo blue stuff will kill them in an hour though, its like 1/2 lead I think
I run VP fuels... I have ran a ratio of 3 to 2 gal of 109 and c16 and it owned my sensors in about 20 gallons of gas.
O2s would die
WG's would die
O2s would die
WG's would die
No knock but the heads lifted. C-16 FTW.
explain the science of how the the C16 would have kept my heads down
KP, yes Im talking about the narrow bands. I wont be going BS3, Im going to switch over now to a FJO dual chanel WB system to feed the stock pcm, no need for BS3
dammit man, you cant complain she was solid for a while, i was just talking about how your car has been flawless and this has to happen, lol,
oh well more time for my car, lol, just kidding
Not trying to start a fight nor argue.
Do what you like.
Everyone is different
