Oil pump swap help needed
Old 03-27-2007, 08:13 AM
joesmith136's Avatar
Default Oil pump swap help needed
I'm doing my head cam swap everything going really smooth I'm using ls1howto.com guide.
I need advice on dropping the oil pan 1/2" to swap a new oil pump I can only get the fron two bolts off any advice on getting to the other bolts does steering rack need to be pulled out?? Really don't want to do that.
Anyone have any tricks to swap oil pump?
2000 M6 Camaro
Installing In progress
MTI Stage IIE Heads
228/228 .600 114 lsa
7.4 Hardened Push Rods
LS7 Cadillac Racing Lifters
LS6 PCV Conversion
LS6 Ported Oil Pump
Old 03-27-2007, 08:15 AM
brad8266's Avatar
You couldnt get an open end wrench in between the pan and the k-member to get those few bolts free?
Old 03-27-2007, 08:43 AM
marv's Avatar
That's what I did as well...
Also, don't forget that there are bolts running through the trans bell housing and into the back of the pan...
Old 03-27-2007, 01:15 PM
01LS6SS's Avatar
Is this in a camaro? Yes then, just use a gear wrench. Easy stuff, dont sweat it.
Old 03-27-2007, 01:19 PM
wssexorz's Avatar
gear wrench works really well for 2 of the bolts ...
remember there are two larger bolts that go towards the front of the car, not up ... without taking those off it will not drop .... also remember to put something in there to stop the bolt from the pick-up tube from rolling in the oil pan .... i spent a good 2 hours trying to get the bolt out cuz it fell way to the bottom of the pan .... it was hell... i was worried i would have to drop tranny so that i could get the pan off
Old 03-27-2007, 05:28 PM
Ya i used gear wrench for two bolts lol about to go back out and go at it again just wanted to make sure there wasn't more to it then just unbolting oil pan a bit
Old 03-27-2007, 05:34 PM
ls1builder's Avatar
if in a f body no sweat in a y body the steering has to be removed no sweat really not a big problem. u should just have to loosen the first two bolts on each side and the pump should slide right off watch the little o-ring cause if u dont get it sealed off right u wont have any oil pressure and u dont wont to have go back in there and do it again just cause an stupid o-ring hope this was useful
