Torn between two tires
I need some opinions. Which ever tire i get will be mounted on 17x11 ZR1's with a 50mm offset.
I can't decide between...
1. Goodyear Eagle F1 GSD-3 in a 315/35-17
2. Michelin Pilot Sport in a 335/35-17
Thanks in advance.
Thanks in advance.
Ive never used the PS2's, but the D3's are the best wet traction tires I have ever used and perform well in dry. If your looking for a good all around daily drver tire the D3 will not disappoint.
Yeah...that's the reason I went with the KD instead of the GS D3, my front tires were down to the cords and I needed a new tire NOW. Since the GS D3 were on back order, it made the choice easy to the the KD out, lower price helped too. And I don't like mismatching tires front to back...looks tacky.
Originally Posted by MannyZ28
They are wrong for sure. They list my tire as having a section width of 12.6" and I measured just over 13 yesterday before putting them on the car today.
Thanks for the help fellas.
Originally Posted by unSStoppable
just ordered 11" 50mm ZR1s and just purchased a set of 315 GS-D3s to go with them (and i did a lot of research prior to buying) if that helps you out at all
Where'd you order your tires from?
The local discount tire co. They matched & beat the best price i could find (275 before mounting, balancing & "insurance")
