What bfg drags for firehawk rims
Old 03-27-2007, 07:39 PM
pHEnomIC's Avatar
Default What bfg drags for firehawk rims
What width are firehawk rims? is it 9 or 9.5? I forgot and am not in town.
I am thinking about bfg drag radials and they dont have the size tire i have now 275/40/17.
What size will fit my rims and work the best for all around driving?
Old 03-28-2007, 09:58 AM
jmm98LS1's Avatar
BFG makes a 275/40/17 drag radial, tire rack has them in stock.
Old 03-28-2007, 01:44 PM
pHEnomIC's Avatar
Sounds good, going with those. Dooes anyone know if my rims are 9'' or 9.5''?
Old 03-28-2007, 02:40 PM
Blknight6989's Avatar
Hey are these the same measuments that woud be on a 98 98 ws6 wheel cuz im getting the same tires????
Old 03-28-2007, 02:47 PM
Y2K T.A.R.A.'s Avatar
On that car, for a meaty nice look... go with the BFG KD or KDWS or if u ant the drag radial... go with 285/40/17
btw ur firehawk wheels are 17x9
Old 03-28-2007, 05:37 PM
pHEnomIC's Avatar
will the 285 fit?
Old 03-28-2007, 05:43 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
No, 275 is max for a 9" wheel. 285 KDs will be way to big for the 9" wheel.
The BFG DRs will fit perfectly in the 275/40/17 size. Not sure what he is talking about by them not looking "meaty"....
Old 03-28-2007, 05:59 PM
pHEnomIC's Avatar
What tires are you running bad ***? Obviously with an almost snapped driveshaft, you are hooking up alright.
Old 03-28-2007, 10:26 PM
BMW ///M Nerd
I have a set of BFG DRs on my factory wheels. The same 275/40/17s... Good tires, and they hook well on the street.
The driveshaft damage actually happened after I broke my factory torque arm after powershifting 2nd gear. I was on 18" Michelin Pilot Sports at the time. Just goes to show how shitty the factory stamped steel parts are...
Old 03-28-2007, 10:34 PM
Phynix's Avatar
why would the 285 be to big, my friends camaro on the stock rims was running the 285 at all corners , my camaro & firehawk as well as a friends firehawk where running 315s on the back only
Old 03-29-2007, 12:52 AM
SO can we run a 285 on the normal rims or not?? Id like to get the widest possbile....does anyone on here have these on their stok 17in fiehawk rims or early ws6 wheels???
Old 03-29-2007, 10:04 AM
BMW ///M Nerd
Because a 285 needs a 9.5" rim. 265/275 are what you want on a 9" wheel. The 275s will be perfect.
315s need an 11" wheel, no questions about it. It's physically possible to mount them up... But that doesn't mean it's right. Tire failure can occur, and then you're going to be sorry.
The manufacture recommends a minimum width for all their tires. Don't be retarded...
Old 03-29-2007, 03:04 PM
dailydriver's Avatar
Since when did anyone make a 285/40 17 drag radial???
Old 03-29-2007, 03:38 PM
pHEnomIC's Avatar
Yeah i am a bit confused as to what he is talking about.
Old 03-29-2007, 03:51 PM
BMW ///M Nerd
Nobody does. Someone started talking about 285 BFG KDs.
You said you were looking for DRs.
I was just making a point that nothing bigger than a 275 should be mounted on a 9" wheel.
Do yourself a favor and ignore his post all-together.
Old 03-29-2007, 10:53 PM
Phynix's Avatar
do you know how hard you would have to push those tires for them to fail, one, I worked for goodyear so i know all about what tire companies recommend and should be done, also the firehawk is running a 743rwhp car and sees lots of hard driviing time with no failure
Old 03-29-2007, 11:12 PM
pHEnomIC's Avatar
Welcome to the internet, where......
Old 03-30-2007, 06:05 AM
Phynix's Avatar
I not trying to say you wrong, just wondering , how many people do you know that have run into this problem, I would agree that its better to run the suggested tire to rim preference
