Advanced Engineering Tech For the more hardcore LS1TECH residents
Lunati crank looks blue after cut?
Old 03-28-2007, 07:30 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default Lunati crank looks blue after cut?
I just got my parts back and i was lookin at my stuff when i got home and the guy who did the work was gone for the day.The journals are fine but the rest of the crank looks blue like burnt or they heated it up.What is that from is this normal when you cut one of these cranks.It almost looks like they put it in a oven.Any input
Thanks,Mike
Old 03-28-2007, 07:41 PM
mr2guru's Avatar
Nitride treated?
Old 03-28-2007, 08:14 PM
tuff's Avatar
Originally Posted by mr2guru
Nitride treated?
Why is that is what it looks like.And if it was,why would they to that on a crank that is damm strong.Even the reluctor ring is blue.
Old 03-28-2007, 08:20 PM
cantdrv65's Avatar
Post
Unfortunately you are going to ask them what exactly they did and why the crank is blue. I guess you could have a hardness test performed on it to see if the metal was compromised but I doubt they got it THAT hot unless it was actually retreated....
Old 03-28-2007, 08:28 PM
mr2guru's Avatar
yeah, it's blueish. Increases journal hardness for wear resistance.
http://www.key-to-steel.com/Articles/Art117.htm
Old 03-28-2007, 09:09 PM
cantdrv65's Avatar
Post
The process involves heating the entire crank in an oven over a controlled temp for a certain period of time. Its done in a nitrogen atmosphere hence the term nitrided. I suppose after being cut that is a really good thing to do as it adds surface hardness....
Edit: Mr2 beat me to it....
Old 03-28-2007, 09:53 PM
tuff's Avatar
I don't what these engine buliders do to are stuff half the time but here are some pics.
Attached Thumbnails Lunati crank looks blue after cut?-crank-001.jpg   Lunati crank looks blue after cut?-crank-002.jpg   Lunati crank looks blue after cut?-crank-004.jpg   Lunati crank looks blue after cut?-crank-003.jpg
Old 03-29-2007, 04:26 PM
mr2guru's Avatar
definately nitrided.... did you pay for that service?
Old 03-29-2007, 05:50 PM
tuff's Avatar
They never asked me if i wanted that done but its not blue all over or is that just the way it looks.I payed 140.00 for the crank to get cut and another 45 for magnaflux.Does that price sound right for nitrided to.
Old 03-29-2007, 07:50 PM
gun5l1ng3r's Avatar
I think the fact that it is not blue all over might mean that it was subjected to an uneven heat, like you would see on a set of headers after some time.
Is it more of a rainbow or more of a blue 'anodized' color?
Old 03-29-2007, 08:19 PM
427's Avatar
Nitride is done to the whole crank, it is normally grey and cost is 125-160 just for that service. It spends multiple hours (I think 8) in the oven coming up to, then lowering down at a controlled rate.
That looks strange, may be some type of induction hardening.
Kurt
Old 03-29-2007, 08:32 PM
6 & 8 Second Club
mrdragster1970's Avatar
Bluing was always a sign of heat, the bad kind.
The shop I use, uses blue for magnafluxing, clean the crank and see if it comes clean. I doubt it will from the little I can see in the pics.
Can't imagine you got anything fancy for that price.
Can't tell much from Pic, but that looks weird. Heat damage of some kind??
Becareful before u put it back together, be safe & good luck.
Old 03-29-2007, 11:33 PM
tuff's Avatar
Now im kinda worryed the shop that did it sends them out.He sayed when i questiond him on this he said the shop who did the crank is a shop that briant reccomends using.And they do alot of big cube race motors.I know just because someone doe's big race motors doe's not make me belive that the crank is right.I will send it out for a second opion before my motor go's together.This just sucks and i don't wanna take any chances.
Old 03-31-2007, 01:09 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default blued crank
As Kurt said, it looks like that crank was induction hardened to me as well.
Do yourself a favor, call Dave at Mile High Cranks in Denver. 303-781-6764
Get his e-mail and send him your photos. It could be that he did the work on your crank. I'm sure he can tell you something about it regardless.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 03-31-2007, 01:46 PM
gun5l1ng3r's Avatar
Do you think it was a controlled process with uneven coloring like that?
I am by no means an expert at all, so I don't really know a lot about what processes can be dones to crankshafts, but if that was my crank, I would have it checked over before I spin that sucker to 7500RPM!
Old 03-31-2007, 04:10 PM
Old Geezer's Avatar
Induction hardening is done in a localized area.. In this case, the rod journals, and the mains..Thus the discoloration...
Old 03-31-2007, 08:24 PM
tuff's Avatar
You hit the nail on the head. That is what i found out.Thanks for all the input guys.
Old 04-12-2007, 03:44 AM
3pnt4maro's Avatar
glad you found out
Quick Reply: Lunati crank looks blue after cut?
