Automatic Transmission - from stock to a vig.3200??
with stock converter my 60ft now is mid to low 1.9s and ets are12.90s@108/109... w/ air lid and 3.73s... whats the average gain.... thanks..
kill_machine85
03-28-2007, 10:12 PM
nice!
SOMe WS6
03-29-2007, 12:04 PM
should be running some 12.5's @ 108 or somewhere close to that.
TERMINAL VELOCITY
03-29-2007, 10:11 PM
.3 to .5 tenths
ok good. .... it came in today , the the precision, transgo shift kit, and crank pulley did also.. ill dig this post up and let you guys know the times..thanks jeff....
PERFECT Z28
04-30-2007, 11:05 AM
Whats the update?
JGKadell
04-30-2007, 12:20 PM
with a good tire and suspension you should see mid to low 1.6 range in your 60' time.
12.53 @108 w/ 1.68 60' warm air
Brads LS1 02Z
05-05-2007, 01:43 PM
Nice!!!
what tires were u running?
BlackHawk T/A
05-05-2007, 02:32 PM
Well looks like he called that one :jest:
he called the hell out of it!!!.............MT DRAG RADIALS..22psi
Brads LS1 02Z
05-06-2007, 02:02 PM
wonder if u could break 12.4x's on a nice cool fall day :drive: :) :drive:
DadsZ28
05-06-2007, 03:01 PM
Just put a 3200 vig in a couple of weeks ago still searching for traction on my nittos. I did hook last week on a prepped track cut a best of 1.71 60 ft. and 12.45@ 109 in decent weather. Before converter i was going high 12.70s to low 80s on 1.9 sixtys. I still cant launch it as hard as i want to or else i'll fry the nittos. Guess the mt et streets would be the answer to 1.6 sixtys and better ets maybe high 12.30s? Also the best et in my sig was in dec in really neg.da as you can see in the mph, my car is trapping normally 108- 109 in normal weather.
DadsZ were you at atco last tues.?
DadsZ28
05-06-2007, 07:58 PM
Not on tues but i was there last friday and the thurs before that when the quick 8s were running. Did I meet you Lc? The cars in your sig look familiar.
SOMe WS6
05-07-2007, 10:45 AM
i'd knew i would be close :)
NC98Z
05-07-2007, 01:33 PM
Don't forget a tranny cooler them Vigalantes can heat up your fluid just as fast as they can fry a Nitto.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
