Disgusted with MT ET Street Drag Radials 275-40-17
NEVER in my life have I spun on 5 straight runs, when NO ONE ELSE at the track was spinning...
This is TOTAL BS..
good smokey burnouts, 1500 rpms launch, 17 psi warm..
Back to BFG's..!
This is TOTAL BS..
Back to BFG's..!
No changes to my car..
They worked fine last week, 7-8 runs...
Today, I was on a sheet of ice, but no one else was...
I polled everyone.. they all ran em @ 17 psi, 1500-1600 launch, all w/ 3600 stall & 3:90 rears... Thats 4 different guys, none of them spinning ...
Plenty of tread, lines clearly visible..
happened to my friend too on a bolt on 3500 stalled LS1 TA with 273 rear gears spun on the street and track....then hooked low 1.8 high 1.7 60' with his street tires on the same track same day. My MT ET street radials are great though maybe MT is having some issues with these tires?
I had them before my 325/45/17 M&Hs. Never took them to the track, but they were horrible on the street. Even hot, they were awful. The M&Hs made all the difference (and the added two inches of height). Even on the street they hook pretty hard (even cold).
Originally Posted by RevGTO
Just a thought ... MT says you are supposed to give them one hard burnout and then just light burnouts afterward if you are doing repeated runs. The way the tire compound is set up, too much burning out has a negative effect on traction with these tires.
Hey Scott,
How do those M&H tires last street driving and how do they handle?
I am looking at some but I am not as familiar with them thanks.
(sorry not trying to highjack your thread !)
I got M/T's and used to have same problem till some one told not to do such a long burn out. I used to smoke-um up but, now I only do a burnout till I see smoke coming up my rear from my rear view mirror. works great now. 1.6 60 ft.
Restricted User
25 degrees over track temp. I heated the hell out of them and spun like crazy, someone told me to do a light burnout and it made a world of difference. Too much heat will make them greasy.
hey if u dont like them.. can u sell them to me haha ill give u some decent moeny, lmk, dumba5s9589@aol.com
